If I'm not mistaken, the picture above your post is the "new spec" which was only briefly tested in Jeddah. There is a kickup right at the front of the rear tire.
The pictires from Jeddah were not so clear (to me) but I think that this one is from Jeddah.
Giorgio Piola said that in FP1 Sainz ran with the new floor (which was tested in Jeddah but didn't race) and Leclerc with the old (which raced in Jeddah).
This makes sense. Just watching from FP1 onboard of both Charles and Carlos, Charles still had a little amount of bouncing. Carlos none whatsoever. Hopefully with this they are able to lower the ride height and find further performance and a broader window.gordonthegun wrote: ↑31 Mar 2023, 23:26Giorgio Piola said that in FP1 Sainz ran with the new floor (which was tested in Jeddah but didn't race) and Leclerc with the old (which raced in Jeddah).
In FP2 both drivers used the new floor.
To be precise it isn't completely new as the tie rod is positioned in a more external position (in the picture I posted above we can see the old tie rod fixing seat).
In this way, the end of the floor should remain more stable. This year the floors can't flex, the cars are designed for such floors, so if the floor moves, the car doesn't perform properly.
It should be the sensor for tire temperature, it's not new.MassaRondo wrote: ↑01 Apr 2023, 03:04https://cdn-4.motorsport.com/images/mgl ... ail-1.webp
The hole in the floor below the R in Rayban is new to me. Looks like an exit… could be a sensor I guess
ing. wrote: ↑24 Mar 2023, 15:16There was mention at the launch of SF-23 of the rear suspension being multi-link and it looks like the upper wishbone may in fact be 2 separate links joined at the outboard (upright) pick-up.JPBD1990 wrote: ↑24 Mar 2023, 10:30As far as new rear suspension goes - it seems to be the great Ferrari unicorn. We heard about new rear suspension coming for the F1-75 several times last season. First it was coming at Silverstone, then after the summer break. As far as I’m aware, the mythical suspension never came? Now we’re back to bringing more mythical rear suspension.
Honestly the amount of rumour and conjecture around Ferrari at the moment is so overwhelming it’s impossible to know which ways up. I’ll believe it when I see it.
Potential mods at the rear could possibly be a change in the spring/damper geometry or the inboard pick-ups to affect anti-squat or anti-lift, so not necessarily very visible.
Scuderia Ferrari believes that at the moment the main problem of the SF-23 is not aerodynamic efficiency, i.e. the ratio between load and drag. In Maranello, in fact, it is thought that the maximum performance of the Red Bull, seen above all in qualifying, is not too far from Red Bull, with the internal impression of always having the potential to fight for pole position. Qualifying in Australia is seen as an anomaly due to human errors on the pit wall and the drivers, which deprived Ferrari of what could have been another front row after Charles Leclerc’s second place on Saturday in Jeddah, later canceled out by the penalty on the grid, and third in qualifying for the Bahrain Grand Prix.
Ferrari is currently working on the mechanical set-up of the suspension to act on aerodynamics, as explained by F1 expert Carlo Platella for formulapassion.it. This means adjusting the static ground clearance and the stiffness of the springs and shock absorbers differently, so as to check how the distance from the ground and the inclination of the car body change when cornering, braking and at various speeds. In other words, in Maranello they try to keep the floor in such a position as to shift the aerodynamic balance of the SF-23 towards the rear, in search of greater stability.
For the moment, therefore, Ferrari continues on its path, until it is thought that the SF-23 can continue to grow. Overturning the concept without the certainty of a clear improvement compared to the current philosophy, of which Mercedes is convinced, would be counterproductive for a threefold reason. In fact, it would force the Maranello team to start from scratch, with little expertise on a concept developed for over a year by its rivals; with the lower cone protecting the passenger compartment not integrated into the bottom, it would be impossible to replicate the sidepods of Red Bull. It would mean Ferrari has to redo the chassis for 2024, with no option to choose whether to reuse the 2023 one instead to save money from the budget cap.
