Thank you, I'll read through that thread.
Has the subject of what happens to flow when the internal sidepod/cooling flow reaches peak and the difference between that and outside flow at higher vehicle speed been discussed anywhere?
Not that I recall. To be honest, it's impossible to accurately predict such details with very limited access to internal ducting. The tubs are used to "increase" the pressure in them after the downward curve above inlet, just like the concave upper surface of the wing, this much we know. Pressure distribution in the tubs was confirmed to me by an F1 engineer as "surface Cp distribution makes sense" - so the unfortunate downvoter can feel free to remove his nonsense downvote.Farnborough wrote: ↑18 Apr 2023, 08:07Thank you, I'll read through that thread.
It's an S duct, it's completely passive, F ducts were driver-controlled. Horizontal mirror brackets are used to help condition the flow around and over the inlet. Inlet flow rate changes slightly with speed, so spillage needs to be under control when thin leading edges are used.Farnborough wrote: ↑19 Apr 2023, 11:18Presumably the vertical exit there (next to the black louvre panel) is coming up from "F" duct entry ? Its quite a size if that's the case.
The two mirror support horizontal elements, are they there to promote a more laminar wash of top side pod surface? A trim plane shift to keep air attached to top surface as I understand it.
Most of the teams seem to have a version of that mirror horizontal item.
The original S-duct—“s” as is the s-shaped flow field created—was meant to accommodate, and so reduce blockage of, the upwash generated by the center, spoon section of the FW, thereby improving its effectiveness.Farnborough wrote: ↑21 Apr 2023, 09:37Apologies about wrong duct identification, was the one they used from under nose and exit on top of tub in front of driver also referred to as "S" ?
Interesting the flow from cooling system (pod entry to exit venting) is not really talked about. The flow through there must at some point peak relative to exterior flow, plus any flow "bulking" around intake now has to travel externally too. This must change the downstream performance considerably.
Will they go back to non single pylon wing after trying so hard in practice and the races to make it work ?Vanja #66 wrote: ↑26 Apr 2023, 15:29New flaps (low downforce) can be seen on the second top nose, noticeably smaller angle and outboard section. Other flaps seem "standard"
https://pbs.twimg.com/media/Fuo9xluWAAA ... ame=medium
We can expect Ferrari to bring either the same rear wing like last year or redesigned with single pylon.
https://pbs.twimg.com/media/FU5-CntWQAA ... ame=medium
Photos by Fabrega
Why the nose is black? I remember they used that colour scheme after the death of Sergio Marchionne or Gianni Agnelli and without sponsors after 11/9/2001 ...Vanja #66 wrote: ↑26 Apr 2023, 15:29New flaps (low downforce) can be seen on the second top nose, noticeably smaller angle and outboard section. Other flaps seem "standard"
Photos by Fabrega
The vanity cover isn't yet fitted. Underneath the vanity cover is exposed carbonXwang wrote: ↑26 Apr 2023, 20:49Why the nose is black? I remember they used that colour scheme after the death of Sergio Marchionne or Gianni Agnelli and without sponsors after 11/9/2001 ...Vanja #66 wrote: ↑26 Apr 2023, 15:29New flaps (low downforce) can be seen on the second top nose, noticeably smaller angle and outboard section. Other flaps seem "standard"
Photos by Fabrega
Why double pylon again? Did they recycle last year one?christian.falavena wrote: ↑27 Apr 2023, 11:12https://uploads.tapatalk-cdn.com/202304 ... 73a28e.jpg
https://uploads.tapatalk-cdn.com/202304 ... ba8d6b.jpg
https://uploads.tapatalk-cdn.com/202304 ... a31602.jpg
https://uploads.tapatalk-cdn.com/202304 ... 198a4b.jpg
Photos by Fabrega.
Seems to have nothing new
Maybe they want to maximize downforce coming from the beam wing/diffuser trying to use the double pylon to straightener the flows? Using the pylon as flow conditioner I meangordonthegun wrote:Why double pylon again? Did they recycle last year one?christian.falavena wrote: ↑27 Apr 2023, 11:12https://uploads.tapatalk-cdn.com/202304 ... 73a28e.jpg
Photos by Fabrega.
Confirmed floor with more external tie-rod as in Australia.
