They read it here first!!!
This is one of the problems with having an overly complex and prescribed rule book.ValeVida46 wrote: ↑26 Apr 2023, 17:59…The Race even did a write up on it if anyone fancies reading it.
Key takeaways:https://the-race.com/formula-1/how-f1s- ... will-work/The draw for the car to be checked is random. As Tombazis put it “we will pull numbers out of a hat tomorrow after the race”.As stripping down the entire car is a lengthy process, the FIA has come up with 20 different areas that can be checked. According to Tombazis, “two or three” of these aspects will be focused on each time – although this could be increased in the future.
Nothing will happen? Really? I would expect Mercedes engines to be turned up. We learned in the past from them their concept allows for trading of power versus durability where as Honda cannot. This was the situation 1 year ago and yes nobody knows if that’s still valid today. Ferrari has so many reliability issues they are hard to judge. But I don’t agree nothing will happen. We will learn after the sprint race when data analysis starts.PlatinumZealot wrote: ↑26 Apr 2023, 02:18Most teams chose to use four PU but they never openly said it. Nothing will change except for less penalties issued.AR3-GP wrote: ↑25 Apr 2023, 20:51In theory there's no reason to need more than 3 because any PU can be detuned. What's going to happen now is teams will run them harder since they don't need to last as long. The cycle repeats itself. They'll be on the fringes of durability next year as well. If you aren't on the fringes, you aren't taking advantage of the regulations and are leaving laptime on the table. The calendar lends itself well to at least 1 or two in-season grid penalties so you would want to run the PUs in a way to maximize this.PlatinumZealot wrote: ↑25 Apr 2023, 20:49It's about time they increased it. Teams were already at the limits of reliabilty for years now. And with the engine freeze and no exotic materials allowed it was silly to keep it a three.
I think they mitigate that for the officials by only checking "1 or 2" of a list of 20 items. It's not an exhaustive process of checking every item.Stu wrote: ↑27 Apr 2023, 07:55This is one of the problems with having an overly complex and prescribed rule book.
Engines & gearboxes have always had to be sealed and removed for full compliance checking (bore/stroke were possible to check at the track). In order for a full compliance check (pun intended) of the suspension system/members these now need to be removed for rig testing.
ValeVida46 wrote: ↑27 Apr 2023, 10:45I think they mitigate that for the officials by only checking "1 or 2" of a list of 20 items. It's not an exhaustive process of checking every item.Stu wrote: ↑27 Apr 2023, 07:55This is one of the problems with having an overly complex and prescribed rule book.
As Tombazis himself says, every team will be subjected to this, after 15 races if a team hasn't been chosen they will be without warning at a following venue. And it's also done with a view that teams need to get their freight on the road asap.
Does anyone have the previous 2 Grand Prix random check teams?
Edit: seems a host of teams were post-race checked in Jeddah and with George Russell's Mercedes getting the random check in Bahrain. Always good to have some perspective, I suppose folk can draw their own conclusions based on fundamentals here as opposed to the alternatives...:
https://twitter.com/fiadocsbot/status/1 ... 1342027824
https://pbs.twimg.com/media/FrnIXelXwAM ... =4096x4096
https://pbs.twimg.com/media/FrnIXtWXgAE ... =4096x4096
https://pbs.twimg.com/media/FrnIX8cWAAI ... =4096x4096
https://pbs.twimg.com/media/FrnIYOqWwAI ... =4096x4096
https://twitter.com/fiadocsbot/status/1 ... 80/photo/1
It's not a complaint at all, it's a correction for this:
"But the cars are fairly specialised nowadays and you can't just start going there and dismantling."
The FIA staff will know in advance which elements of the car they intend to address.
"We are going to be splitting the car in approximately 20 macro areas," Tombazis explains. "And we're going to be selecting two or three to check thoroughly each time. As we build a bit more confidence and we make sure the logistically we can handle it, we may increase that, hopefully."
No, calling it a strong word is just no more than your perception. In fact it is a violation without consent, where the 'sexual' part of it is obviously metaphorical aimed at the intimacy of the proven formula over decades.PlatinumZealot wrote: ↑27 Apr 2023, 07:24Rape?langedweil wrote: ↑26 Apr 2023, 15:38Just stop raping the sport ..
Like a crowbar, some things are just close to perfection and simply need no improvement.
Strong word. Last time i checked rape is taking by force and leaving the victim indignified and mentally and sometimes physically damaged. The sport is the healthiest it has ever been actually.
F1 nearly perfect?
Maybe when viewed through your rose tinted glasses. For me there is always room for change.
I'm not sure how accurate that is. Hamilton has been in an interview saying they have upgrades for this race.
I was just going off of what Toto said previously (no upgrades until Imola). I stand corrected if Hamilton said something different. Although I should have known better than to take Toto's word for anything
It is a random process that when selected, the FIA... not the teams, will know what they want to look at.AR3-GP wrote: ↑27 Apr 2023, 15:15I still think you don't understand what I wrote so perhaps the third time is the charm. A random selection process is just that, random. This part is clear in the regulations. The car number is randomly selected out of a hat. Car 1 was selected at random after Australia for a deeper inspection.
Are you still with me? ok, great.
Now...
The latter part of this procedure is no longer random. The specific items of the technical inspection are not random.
Do you understand now? Of the 20 macro areas, they wanted to thoroughly inspect the suspension systems of the RB.
This comes with the backdrop of suspicions surrounding abnormally low ride heights (made by other teams), and other trick suspension which had been made by the other teams. If you want to believe in coincidences, that's on you. I don't. There are few coincidences in F1.
If it's teams informing the FIA of illegality, why would they leave it to a random process that may take up to 15 races to come to fruition?As the FIA is already able to perform extra checks on cars it has suspicions about, there is no reason for it to make the selection non-random
All teams are deeply suspicious of their competitors, that maybe team X or Y is doing something, I’m sure that on occasion, maybe some things may have happened below our radar. So we don’t have any suspicions, but it’s good practice to start checking the cars a bit more thoroughly.
I never said that the teams have the power to tell the FIA what to inspect in a random inspection. I only said it's possible for ongoing discussions and whispers to influence the direction of the FIA, even though their processes are supposed to be independent.ValeVida46 wrote: ↑27 Apr 2023, 16:30
So why would it be a "team fishing expedition"? There's literally no foundation to make that claim.
Especially since a technical protest is an avenue for any team. And...that if the FIA suspects any illegality it doesn't need the random selection process to inspect a car as per:
If a protest is lodged or the FIA has a suspicion, they can inspect it immediately. No need for a random process.
Palming this off as some "fishing expedition" is therefore without any foundation as outlined by the process, and by the fact there's nothing to substantiate as a seditious plot by teams to catch Red Bull out.
From that very story Tombasiz says this too...All teams are deeply suspicious of their competitors, that maybe team X or Y is doing something, I’m sure that on occasion, maybe some things may have happened below our radar. So we don’t have any suspicions, but it’s good practice to start checking the cars a bit more thoroughly.
