PlatinumZealot wrote: ↑13 May 2023, 21:19
organic wrote: ↑13 May 2023, 19:35
PlatinumZealot wrote: ↑13 May 2023, 18:50
Expecting a zero-pod-ramp-undercut.
It has already been demonstrated a mid-wing is not compatible with undercut.. another feature of the zeropod is the inlet running to the floor which prevents undercut. so the features that make it the 'zeropod' also preclude it from having undercut; yet you expect it to be zeropod with undercut.. how so?
Why are you inventing things now? Have you modelled this?
The reg prohibit them using any other angle on the face of the zeropod/pod. Any sidepod would have the use the volume behind the area dedicated to the side pods.
Lets face it....is it really going to be effective if you keep the current setup as it is now with the straight down to the floor, then make a sidepod after it? I cant see it at all. You want the air to go into the inlet and then be channelled under and around the sidepod/engine cover towards the diffuser.
Then you have the problem that the sidepod as present is sooo far back compared to every other team a lot of your area where the beginning of the sidepod undercut start is already gone and is open air due to the beam wing and its associated profiling to make it legal.
Images courtesy of AlbertFabrega on Twitter.
Just look at how much of the udnercut Merc would lose out on if they tried to adapt a sidepod after their current setup. At a rough guess, the Merc sidepod/zeropod intake starts between the O and R on Oracle on the RB19
