Red Bull RB19
Farnborough
Farnborough
95
Re: Red Bull RB19
In post above, is anyone else getting the impression the exhaust pipe is smaller at the opening (very marginally) than the bore size further back toward the engine ?
It's odd because from pure image recording (optical geometry) the end nearest to camera "should" look the largest in perspective.
I know these dimension are tightly controlled in regard to the specification, also for vertical alignment etc, but it appears slightly different.
Re: Red Bull RB19
Yes the monkey seat is new for the rb19. Is visible on their high df beam wing that they've used since Bahrain:
Pic from preseason testing with monkey seat present
Feature was not present on high df BW in '22.
Re: Red Bull RB19
Also a feature inspired by competitors, as is the diffuser corner geometry :p
When you have only two pick up points for top beam wing (one on each endplate) it's easier to let it flex :wink:
Re: Red Bull RB19
Nicolas Carpentiers 📸
A good comparison of the new diffuser geometry with the pre-barcelona diffuser. The corner geometry has completely changed: the RB used the curved corner since launch RB18 and was an outlier in this regard. Now they have finally adopted the squarer shape that was predicted prior to 2022 which maximizes usage of the legality volume.
I believe if the squarer shape is to be achieved, the inwards bulge is required prior to the final diffuser kick due to stringent minimum radius rules in this region. But this may be incorrect if someone more knowledgeable with the regulations knows better
As previously stated, the edge wing has changed. This is not a novel comparison nor a novel conclusion but hopefully some crude annotations will help add a bit of accessibility to the understanding of the geometry. It could be perceived as adding a strake.. but if you follow each edge of the edge wing carefully the edge wing is essentially twisted such that the underside of the edge wing becomes the top and vice versa:
This probably allows them to crank their edge wing harder without having to attach lossy metal strakes to the underside of the edge wing
Not 100% sure if the purple edges connect up on the updated edge wing (but this is not visible). Regardless, the underside of the edge wing is far more complicated and this gives a decent view of how it might be working
*Reposted with pc annotated images rather than phone
Edit:
In hindsight, perhaps this is a possible geometry as well
With the red edge originating in a strake on the underside, and the green edge merging with the purple edge which removes the possibility of the twist occurring
dialtone
dialtone
118
Re: Red Bull RB19
organic wrote:Nicolas Carpentiers
That edge wing is so nice. I know nothing of aerodynamic design but the torsion really feels like it’s generating the vortex while massaging the flow to seal the back of the diffuser from tire squirt. This may be totally wrong but the amount of 3d structures that RBR uses feels like they are using a completely different cfd software for modeling. That they have the same computational limits as everyone else feels almost unbelievable.
Tip of the hat, this one detail more than anything in the car feels magic to me.
dren
226
Re: Red Bull RB19
I don't think you drew that Barcelona one correctly. It looks like they bent the front component more to make a sharp transition at the lower part.
Honda!
Re: Red Bull RB19
dren wrote:
07 Jun 2023, 13:58
fully open to this being totally wrong :D as working with this strange geometry is just speculative.. However I don't understand exactly what you're getting at - can you illustrate it please?
Looking at it with fresh eyes.. Perhaps this geometry is also possible? with the green edge curling inwards to join the purple edge which continuously runs inboard whilst the new outboard edge originates with a strake on the underside of the wing
Re: Red Bull RB19
Another angle.
Re: Red Bull RB19
I give up :D I am confident that both of my interpretations were incorrect with that additional angle taken into account.
Re: Red Bull RB19
Another angle from Fabrega. I'm not too sure how these pieces are joined.
Re: Red Bull RB19
Chuckjr wrote:
03 Jun 2023, 09:14
SiLo wrote:
01 Jun 2023, 10:31
https://i.imgur.com/lC9yt9E.png
Just trying to highlight some of the curvatures of their underfloor.
Could it be RB are using the steps in the floor to reduce drag in a similar philosophy used in boats to reduce drag?
“The most recent change in this design over the past decade has been the incorporation of strategically placed notches or steps in the hull. The steps create air bubbles, raising the hull off the water on a drag-reducing cushion.”
https://tntcustommarine.com/2019/06/hi- ... ull-types/
And here:
In that very same video "increased resistance to porpoising" was given as an advantage of a stepped hull in boats. Whether this translates to a car floor remains to be explained by someone expert in fluid dynamics.
marcel171281
marcel171281
27
Re: Red Bull RB19
08 Jun 2023, 01:27
https://i.redd.it/albert-fabrega-red-bu ... 628f6ff7a9
Looks like one of those Escher drawings :lol:
Re: Red Bull RB19
07 Jun 2023, 14:02
I think this is the correct one with the modification that the green edge does not join the purple edge in the right side of the picture. The green edge simply blends/diffuses into the cambered interior section of the floor edge body and ceases to exist.
deadhead
52
Re: Red Bull RB19
Re: Red Bull RB19
Wing element reprofiling for more front downforce. Will make a comparison soon.
