Is it possible this is the result of Perez being in a long train of cars, so his top speed is likely to be significantly affected vs Verstappen in clear air?Vanja #66 wrote: ↑20 Jun 2023, 13:35So for some reason, Max was clipping his top speed at the start of the race again this year. Perez does not do that. Moreover, Max also did it last year - and the top speed difference in final laps is up to 10kmh. Haven't seen any other driver doing that, any ideas what's going on?
This happened in Bahrain too this year, but there was some issue then, or at least that was an explanation.
https://i.ibb.co/NVb14QS/22-23-canada-ver.jpg
Then his fastest lap attempts likely were in a higher engine mode.
