Juzh wrote: ↑30 Jun 2023, 18:01
denyall wrote: ↑30 Jun 2023, 17:55
Juzh wrote: ↑30 Jun 2023, 17:51
Are a joke. Shouldn't be this game of centimeters.
The walls of Monaco and Baku are millimeters, so I see no issue. The track is the track, off the track is off.
Nah, it's not the same. Some puny white lines can't hold same significance as solid walls or gravel, I dont care what those BS rules say. If kerbs were the limits as they were for years and years then this would be avoided entirely or at least in 95% of cases.
Track limits are entirely in the control of the driver - they go out that wide because it's faster. But they decide how far to push it, no one else. To then complain about it is silly - just don't go out there.
The answer is to make going out there slower than not going out there - a 1m wide strip of gravel or wet AstroTurf immediately behind the ribbed kerb. The drivers will then miraculously be able to ride the edge of the kerb and avoid the nasty stuff on the other side.
It's good that they enforced them, it's a shame it takes so long to do it.
