2023 Austrian Grand Prix - Spielberg, June 30 - July 02
Matt2725
Matt2725
Re: 2023 Austrian Grand Prix - Spielberg, June 30 - July 02
nevill3 wrote:
02 Jul 2023, 22:00
The document specifically refers to turns 9 and 10 only not turn three
Yes that did confuse me. It was almost as if they didn't care about anywhere else on the track, only T9 and T10.
I wouldn't take it personally if I was running an affected team but doubt it'll be entertained to be looked at again.
chrisc90
Maybe all this Track limits thing needs is a pressure sensor the exact distance from the white line as the wheel width of the cars. Presuming they are all identical width.
Touch the pressure sensor with your left wheels, means your right wheels is over the line.
Hang on.. were all of those who received further penalties drivers that had already received 5s penalties in the race?
It seems like everybody who escaped a 5s penalty in the race escaped further interest from the recent review. Norris, Perez etc who seemed to be breaching it constantly for instance
nevill3
16
Teams have the right to appeal
vorticism
323
Big Tea wrote:
02 Jul 2023, 22:07
TBH, I think if FIA keep up the zero tolerance, it will be a non issue after the break., but other than that, what's wrong with the original tennis method of powdered chalk?
It would show up instantly as a blaze on the tyre and is completely harmless and costs hardly anything.
Who the poor guy that has to reapply the chalk every lap?
𓄀
chrisc90 wrote:
02 Jul 2023, 22:11
The problem is that the contact patch and the shadow cast by the tire are not the same.
A lion must kill its prey.
dans79
267
vorticism wrote:
02 Jul 2023, 22:07
That's true; and those are examples of grass leading to shunts, for sure. But that's also the point. Grass may cause a shunt, ideally not a bad one. That's where the asphalt instead of gravel/sand/more grass/uneven terrain comes in. Since the that's what seems to be causing the severe instances, not the grass per se.
So, Suzuka but optimized, you might say.
IMo, the main issues is the FIA's strait up unwillingness to change anything safety wise until someone dies, or has a career ending accident. Halo, vsc, etc all because of Jules.
As i've mentioned already track limits could be monitored in real time accurately, with tech you can find in kids toys.
201 105 104 9 9 7
Big Tea
02 Jul 2023, 22:13
chrisc90 wrote:
02 Jul 2023, 22:11
The chalk would only be on the contact patch
Big Tea wrote:
02 Jul 2023, 22:07
powdered chalk would need to be re-applied mid-race.
dfegan358
dfegan358
-2
I find Ocon the most unlikeable driver I’ve come across in many years of watching f1. I take no pleasure in having that opinion but I just find him very hard to warm to for some reason
dans79 wrote:
02 Jul 2023, 22:14
vorticism wrote:
02 Jul 2023, 22:07
Monitoring track limits has nothing to do with safety. Racing is dangerous. Every circuit shouldn't look like Paul Ricard.
chrisc90
02 Jul 2023, 22:13
chrisc90 wrote:
02 Jul 2023, 22:11
I believe the limits are the tyre if you drew a box around it rather than the contact patch?
Could easily make the sensor a few CM high, like a little rumble strip, which would still contact the tyre taking into account the camber etc.
Big Tea
02 Jul 2023, 22:14
Big Tea wrote:
02 Jul 2023, 22:07
No, or at least not unless lots of drivers went on it. It can be put on 'wet' with linseed oil and it dries to a sort of bar that can give several 'dabs'. I am guessing but I thing 10 or more. It is sometimes used to check if a conveyer belt is scuffing.
Big Tea wrote:
02 Jul 2023, 22:17
02 Jul 2023, 22:14
Big Tea wrote:
02 Jul 2023, 22:07
We just has "1200" potential offenses today :lol: . Eventually the width of the chalk line would be "spread" as cars run over it, not to mention having to reapply it where it was worn out. It seems very finnicky.
Big Tea
02 Jul 2023, 22:18
Big Tea wrote:
02 Jul 2023, 22:17
02 Jul 2023, 22:14
Ah, that would be a problem :mrgreen:
Have a safety car?
