AR3-GP wrote: β08 Jul 2023, 17:52
dialtone wrote: β08 Jul 2023, 17:38
What if I told you that McLaren should start 1-2 the race and Max should be penalized?
You probably got excited about this
. The light signal is for sector 2, not sector 1. This has come up several times over the years.
Remember seeing the green flashing lamp post right in Baku 2021 just next to Verstappen's crashed car? That's because the light signal is for the following sector.
Excited?
My man... Max is going to fly by in 2 corners, it makes no difference to the final result of the race, it's not exciting in the least, just curious.
And as I wrote in the other post, panel 05 is on out of T4, then 06 seems off and 07 is on again, it's weird as the issue was far from S1 anyway but 05 was on so there's no point in not having 06 on too unless it's broken. Also apparently some drivers had the yellow flag light on the wheel and others didn't.
