The only common feature really is the leading edge shape which is the same due to both pieces of bodywork being up against the front of the sidepod bodywork regulation boxBlueCheetah66 wrote: ↑20 Jul 2023, 21:16Its not in any way comparable to the Mercedes Mid-Wing apart from the fact that it is shaped in an a aerofoil, likely to get cleaner air in to the inlet.
