Floor/diffuser pic - Belgium
Xaviimages
Brightened:
Was looking on twitter and just came here to say this!
The centre part for sure looks RB19-esque. Two stepped flowing contour lines (only way I know how to describe it). The actual diffuser expansion zone seems to be fairly simplistic. Clearly is bringing them lots of predictable DF
From what I have been able to see from on-boards they are using this to bleed off downforce at speed, whilst using the plates at the end (inboard as most have located the adjustment outboard) to create a shedding edge above & below the trailing edge when flexed.Farnborough wrote: ↑02 Aug 2023, 22:34Anyone else see just how much the front wing bends down and back as speed/load comes onto it ?
In car footage you can see it through between front suspension elements, others not so visible, but it's significant and clearly visible on this car.
The hole above the upper suspension arm is new. Red bull has this also, but not in this position. The guess is, that this is for blowing the beam wing.NiyolHuayra wrote: ↑27 Jul 2023, 16:03Via Twitter @AlbertFabrega:
https://pbs.twimg.com/media/F2C_OepaIAE ... name=large
