wuzak wrote: ↑06 Aug 2023, 11:52
I think it is.
More to the point, deploying at the same power as is recovered.
Recovering power from the front wheels won't make the problem of burning fuel go away - it will reduce it some, but not eliminate it.
Having a difference between the power of recovery and deployment will stretch the time that power can be deployed, and further reduce the need to burn fuel.
If front recovery was to be allowed, it would make sense to have 600kW recovery/350kW deployment like in FE.
That's just an arbitrary opinion. It is a fact however that there's a lot more energy to be had if you recover from the front as well, at least double in the worst case scenario, but in most circumstances a lot more.
Someone calculated before here on F1T that the real wheels would lock up at a rather high speed with 350kW recovery, so during much of the braking you can't utilize near as much. Not so much the front wheels, which obviously have far more force pushing them down during braking and always bear the brunt of the braking force.
On the other hand during deployment it's easy to use up the stored energy. (Especially with the ICE regressing in power) The main concern is not to use up too much and end up with a power deficiency towards the end of the lap.
Moctecus wrote: ↑06 Aug 2023, 11:56
This is what Pat Symonds told AMuS about the proposed front recovery:
"According to our calculations, it would have taken 18 kilograms extra for two 130-kilowatt generators (176 hp) including half-shafts, a differential and the wiring. We would have tapped the remaining 130 kilowatts from the back. With this solution, we could have reduced the tank capacity from 110 to 70 kilograms and practically completely dispensed with fuel burning for energy generation."
Indeed. That comment form him was one of the things I had in my mind.
