Agreed.
Why are you so upset? People get pushed off track all the time to avoid being passed or to pass.Just_a_fan wrote:There were people calling for quite draconian penalties - drive-throughs, 10s stop-and-go, etc. They are pretty much a lynching in motorsport terms.Cs98 wrote: ↑05 Sep 2023, 16:42If you break the rules and cause a crash you get punished, that's what happens. And sure, you can place faith in the other driver to get out of the way of your mistake. But that's a risk the rule-breaker is taking, if something does go wrong you will have to take responsibility because it was you who broke the rules, not the the other guy. It's really not that difficult.Just_a_fan wrote: ↑05 Sep 2023, 16:02So squeezing a skilful/lucky driver on to the grass is OK. But squeezing someone on to the grass who is unable to control their car for whatever reason is grounds for hanging from the nearest tree. OK, at least we know the ground rules going forward.
And enough with the lynching rhetoric. It's not befitting the topic of a 5 second penalty, nor this forum at all really.
I don't find it strange at all in other walks of life. You crash into another car under the influence and the person in the other car passes away. You think you are getting off with more or less time served than if they are unharmed? You run a red light and cause a crash, more or less punishment than if the crash was avoided? The outcome of illegal activity is a consideration when determining what is appropriate punishment.Of course, this approach basically reverts to the idea that the outcome should be punished and not the action. Which is a strange approach in most walks of life.
Yes, serious offences do carry further punishment, but you still get a punishment for "victimless crimes" such as speeding. Drive at 60mph on an empty 40mph road and you get punished. No one is hurt but the rule has been broken. But at Monza we see people causing others to go on to the grass and it's considered ok so long as they don't crash - "no harm, no foul", a so-called "victimless crime". But that's not how rules should be implemented. You break the rule, you get a penalty. The outcome should be irrelevant to the question "was the rule broken?"
Well...the ridiculous point is that George knew exactly what he was doing. Smart...well executed.
If you violate the rules you should be penalized. F1 penalties shouldn't be outcome based, or driver based, or track dependent.
Is tire deg low? Teams deliberately ran the M-H tires even though the soft was available. So it might not be a case of tire deg being low, but teams simply using the harder compounds to avoid tire deg.Sofa King wrote: ↑05 Sep 2023, 18:38Does it seem like tire deg is very low this year? All of the top ten drivers this race did a one stopper. To create more strategic opportunities and excitement in the race, hopefully next year’s compounds/tires are developed and selected to make a one stopper more the exception and only viable when starting on the hardest compound in a dry race. That should create a more stark tradeoff between hanging long for a safety car/one stopper and a two stopper with softer tires to get a better start off the line
How could I possibly let this slip past. Sainz ran into Alonso and it had nothing to do with Gasly or Ocon. We have discussed this at length. I don't plan to concede.
Which could have been solved simply and immediately by the FIA ordering Russell to give the position back, of course common sense is not one of their strong points.chrisc90 wrote: ↑05 Sep 2023, 18:13Agreed.
I also wonder if having an additional penalty (the lasting advantage) should be given IF the driver who overtook off track and failed to give the position back.
It shouldn’t really be a one or the other scenario. Russell overtook off track, failed to give the position back AND gained a lasting advantage. That should be worthy of two penalties in my opinion.
Yep, the rule should be that the position needs to be given back within 3 corners - which is more that sufficient or you get a nice hefty penalty thrown at you. (Or +5 seconds if the car behind takes a pitstop and unable to give the position back within the time frame)Astro85 wrote: ↑05 Sep 2023, 22:15Which could have been solved simply and immediately by the FIA ordering Russell to give the position back, of course common sense is not one of their strong points.chrisc90 wrote: ↑05 Sep 2023, 18:13Agreed.
Right, but if the FIA informs the driver over the radio then it saves all confusion as to whether they believe the place should be handed back and certain situations, and, if, like you say they don't hand the place back then go ahead and penalize them, no driver would ever ignore the order.chrisc90 wrote: ↑05 Sep 2023, 22:24Yep, the rule should be that the position needs to be given back within 3 corners - which is more that sufficient or you get a nice hefty penalty thrown at you. (Or +5 seconds if the car behind takes a pitstop and unable to give the position back within the time frame)Astro85 wrote: ↑05 Sep 2023, 22:15Which could have been solved simply and immediately by the FIA ordering Russell to give the position back, of course common sense is not one of their strong points.chrisc90 wrote: ↑05 Sep 2023, 18:13
Agreed.
Probably worthy of another topic, but in todays races is 5seconds ever really a ‘penalty’? When there’s gaps of 10+ seconds between some drivers, it’s no longer a penalty so to speak given the gaps in front and behind can differ quite a bit. If penalties were 10-15seconds minimum - people would definitely think twice - given it’s bound to have a negative effect on your race
The discussion isn't about the past. We cannot change and retroactively fit punishments to past transgressions. All we can do now is focus on the future. What shall we do to prevent drivers from getting too clever.ringo wrote: ↑05 Sep 2023, 23:03How about teams consciously breaking cost cap rules?chrisc90 wrote: ↑05 Sep 2023, 18:13Agreed.
Russel could have only been punished to the letter of the rule and no more. Going beyond that gets into complications.
Suprised these minor aspects of the race are still being debated. Move on folks!
The teams have a way of racing to the life of the tyre. They will always do this unless the degradation or cliff costs more than a pitstop. (24 seconds). And Pirelli cannot go too soft for safety reasons and worse they cannot increase pressures too high because the drivers don't like the feel of it.Sofa King wrote: ↑05 Sep 2023, 18:38Does it seem like tire deg is very low this year? All of the top ten drivers this race did a one stopper. To create more strategic opportunities and excitement in the race, hopefully next year’s compounds/tires are developed and selected to make a one stopper more the exception and only viable when starting on the hardest compound in a dry race. That should create a more stark tradeoff between hanging long for a safety car/one stopper and a two stopper with softer tires to get a better start off the line
