does anyone have info on its components ans operation etc plus pictures of this type of suspension on the cars
thanks
viewtopic.php?f=6&t=6350mx_tifosi wrote:
or search our forums...
BTW, welcome to F1T.
Would be true if it wasn't for the fact that the springs are on the same side of the pullrod as the dampersriff_raff wrote:Pull rod suspensions were popular for a while in F1, since the thin section pull rod had less drag penalty than a push rod. But most cars reverted to push rods since the thin section pull rod could not handle the compressive forces required for suspension rebound dampening.
Torsionally stiff F1 chassis tubs with aero configurations that are super sensitive to changes in pitch and roll, require all four tires to be in constant contact with the track under cornering, acceleration and braking. So if a wheel gets bumped up going over a curb in a corner, it needs to be pushed back down onto the track ASAP by the suspension pushrod. How quickly the suspension responds is a function of the rebound force. A stiff push rod can accept more force than a thin push rod in compression, so a pushrod suspension would allow higher rebound rates and would have better mechanical grip in cornering than a pull rod system.
But the largest masses/inertias that the dampener is designed to control are attached to the far end of the the pull rod. One important requirement of rebound is to ensure the tire maintains contact with the track surface after bump travel. The slender pull rod is very limited in the amount of force that can be applied by the spring to force the tire/wheel back onto the track surface after a bump motion. The same is true with transfer of roll bar forces from side to side. The amount of force that a slender pull rod can handle in compression without buckling is very limited.PhillipM wrote: Would be true if it wasn't for the fact that the springs are on the same side of the pullrod as the dampers
You mean the dampers of course?WilliamsF1 wrote:Ferrari pull rod suspension the springs are arranged vertically as in the conventional push rod suspension.
In the 90's F1 cars springs were arranged horizontally, would this have been more of a benefit for Ferrari had they adopted it?
http://community.evo.co.uk/users/PRM/ph ... 31542b.jpg
Means the same (I hope)PlatinumZealot wrote:You mean the dampers of course?WilliamsF1 wrote:Ferrari pull rod suspension the springs are arranged vertically as in the conventional push rod suspension.
