whats with the two 'antennas' on the front wing (near bridgestone)?
Are the exhausts new as well? much flatter? or may just be the photo angle or at they were at germany lol
they are the supports for the cascade wing element that is mounted (or not in this case) the endplateastracrazy wrote:whats with the two 'antennas' on the front wing (near bridgestone)?
they haven't, they've added the missing section later onastracrazy wrote:Sorry if im being stupid! so why have they just left the supports there?
Is there any other updates to anyones knowledge
McLaren seem to be on a charge to make this a closed wheel format?zgred wrote:
an extra 80Hp will make any turd faster in a straight line!nudger wrote:so, it seems you really can polish a turd
kudos
dont be mad, RBR can still incorperate KERS, then it will be your best frienddjos wrote:an extra 80Hp will make any turd faster in a straight line!nudger wrote:so, it seems you really can polish a turd
kudos
I still dont like the concept, it was a pathetic & expensive attempt to green-wash F1!ISLAMATRON wrote:dont be mad, RBR can still incorperate KERS, then it will be your best frienddjos wrote:an extra 80Hp will make any turd faster in a straight line!nudger wrote:so, it seems you really can polish a turd
kudos
well as it stands today RBR look like fools to not have taken the 80 hp bump which costs you no fuel(weight)djos wrote:I still dont like the concept, it was a pathetic & expensive attempt to green-wash F1!ISLAMATRON wrote:dont be mad, RBR can still incorperate KERS, then it will be your best friend
