2023 - McLaren Formula 1 Team
Re: 2023 - McLaren Formula 1 Team
MrGapes
33
first laps car overheated.. they will probably open up some of the cooling gills
MrGapes wrote:
17 Nov 2023, 06:40
Mclaren have not been known for getting their cooling sums right...
FittingMechanics
FittingMechanics
16
17 Nov 2023, 07:45
MrGapes wrote:
17 Nov 2023, 06:40
It's why there is FP, you test boundaries of what you can do.
Btw I'm optimistic that less FP running is good for the team, in sprint weekends they usually did well.
mwillems
42
The flap being reprofiled suggests that soe minor changes to the existing flap. But a new beam wing as predicted to work with this config.
-Bandit
trinidefender
trinidefender
317
17 Nov 2023, 07:45
MrGapes wrote:
17 Nov 2023, 06:40
Errr, when last did they have any large issues with cooling? Maybe you're thinking of the other team beginning with M.
Pretty much every team has issues running in traffic for extended periods of time
Lando's bodywork is coming off. Engine issue I think?
FittingMechanics
FittingMechanics
16
17 Nov 2023, 12:39
Lando reported that he is bottoming out very heavily. Team is rising ride height for both cars now. Lando also has a small cooling issue.
FittingMechanics
FittingMechanics
16
Still a lot of bottoming/porpoising for Lando.
FittingMechanics wrote:
17 Nov 2023, 12:54
Lando back in again. What the heck is going on!
MrGapes
33
car certainly out of its sweet spot so far.. porpoising/bottoming in high speed looking pretty scary, and no front stability under-braking or rotation.
MrGapes
33
after second changes.. they definitely lifted the ride height a considerable amount... less bouncing, and quicker on the straights.
quite unstable rear and understeer through first 1-2-3-4 complex, braking into turn 7 is probably the worst bit, car is still unstable through 11 hence braking into 12 is compromised.
FittingMechanics
FittingMechanics
16
Does seem like they are on the back foot with the setup but I am confident the team will figure it out.
"Both drivers debriefing. Neither is particularly happy with their car."
Tomsky
Tomsky
29
Apparently, the wing for Monza does not roll here, you need a little more, like for a Spa, and we don't have it.
FittingMechanics
FittingMechanics
16
Tomsky wrote:
17 Nov 2023, 13:40
I bet the team has the other wing as well but they haven't mounted it. It's not a job you do in middle of a FP.
