RB20 speculation
Ozan
Ozan
Re: RB20 speculation
CaribouBread wrote:
15 Feb 2024, 09:06
Andi76 wrote:
15 Feb 2024, 08:31
That dark bit confused me too, but from another angle that's just the mirror stay/turning vane - visible on both sidepods. (ar3gp's image)
https://i.postimg.cc/k4gN7ps2/image.png
this is definitely like last year's mercedes sidepod
wiktor977
wiktor977
25
Cs98 wrote:
15 Feb 2024, 14:02
wiktor977 wrote:
15 Feb 2024, 13:53
This whole debate about underbite/overbite, looks like "push vs pull" debate. Both solutions have pros and cons. But fundamentally it all depends on what the team wants to achieve in terms of airflow management. Did Mercedes made a mistake scrapping overbite idea based on what Red Bull is doing now? I would say no.
The suspension debate has had a clear convergence towards push-rod rear and either one front. This is much more intriguing because you had the dominant car of all time incrementally developing towards more underbite, only for its successor to flip the script. Meanwhile you have everyone else (except McL) going towards underbite or removing their overbite (Merc). The emperor has swapped clothes with the peasants :lol:
I don't agree with you on the push-rod, but that is not the point. Yes, it's intriguing that Red Bull changed the approach, does it mean that every other team with underbite is wrong? Hell nah.
dren
226
vorticism wrote:
14 Feb 2024, 22:28
14 Feb 2024, 21:58
Did some messing around with various photos and ended up with this one that might give the best view of the inlets so far
https://i.imgur.com/WzPc1Zy.jpeg
https://i.imgur.com/YyPdkru.jpeg
+1 Starting to see how far the upper forward suspension mounting has been moved backward.
viewtopic.php?p=1184785#p1184785
Compare to RB19:
https://i.postimg.cc/XvNjnmR5/susp-front-rb19.jpg
14 Feb 2024, 21:58
I'm not sure if it has moved much if any. Don't use the driver number for comparison, use the pitot tube. It looks like the driver number location is moved closer to the cockpit.
Honda!
BlueCheetah66
BlueCheetah66
33
dren wrote:
15 Feb 2024, 15:27
vorticism wrote:
14 Feb 2024, 22:28
14 Feb 2024, 21:58
Compare to RB19:
14 Feb 2024, 21:58
Tbf it seems they have moved some of the livery aspects around so it isn't great to use them to compare. From that picture is looks as though the suspension arm has move above the red line along the side of the chassis, but from other angles it can be seen that that line itself has moved down.
Venturiation
Venturiation
98
Clearest image i could get a traced how i see the overbite
Isn’t today launch day? Where is the car?
A lion must kill its prey.
LM10
LM10
121
15 Feb 2024, 16:11
7.30 PM GMT
chrstphrln
wiktor977 wrote:
15 Feb 2024, 14:53
Cs98 wrote:
15 Feb 2024, 14:02
wiktor977 wrote:
15 Feb 2024, 13:53
This all reminds me of the late 90s to early 2000s.
First you had to have a highnose, then you had to take it down again because of McLaren, after Ferrari became champion in 2000, even McLaren raised it, only to find that the Italians wore it down again in 2001...
At some point later, all teams had them somewhere around the middle.
Venturiation
Venturiation
98
it's confirmed the car has vertical inlets
https://www.gazzetta.it/motori/red-bull ... cali.shtml
Emag
Emag
83
Venturiation wrote:
15 Feb 2024, 16:25
It's almost comical how they are following so many of the W14's ideas (be it launch spec, or post monaco), whereas Mercedes themselves has seemingly abandoned these to go in favor of ideas initially introduced by RedBull in their W15
Matt2725
Matt2725
Emag wrote:
15 Feb 2024, 16:35
Venturiation wrote:
15 Feb 2024, 16:25
To be fair, Mercedes were quite clear that the sidepods weren't the issue. Although the driving position Hamilton complained about was as a result of having the bury the radiators in the chassis, elongating the fuel tank. Their cooling solution is either similar, something not even thought of or compromised as Merc had in the W13/14 causing them to turn the engine down somewhat.
Venturiation wrote:
15 Feb 2024, 16:25
:lol: this is Gazetta. It's speculation no better than on here.
Cs98
Cs98
33
wiktor977 wrote:
15 Feb 2024, 14:53
Cs98 wrote:
15 Feb 2024, 14:02
wiktor977 wrote:
15 Feb 2024, 13:53
We don't have the answer to that question yet, but so far RB has proved to be the most credible team in terms of concept during this regulation set. If they changed from something that was working they wouldn't do it on a whim.
Giando
93
15 Feb 2024, 16:37
Venturiation wrote:
15 Feb 2024, 16:25
being italian... I agree!!! :mrgreen:
Cs98
Cs98
33
Vertical inlet? Where?
