If I understand you right Dave, we are talking vertical wheel-load versus flexibility at spring pick-up point?
But still, 2000 N/mm, it's not xactly mindboggling is it?
One issue you missed... how big are the hands of the mechanic that adjusts the suspension and whether or not he cusses a lot or not...scarbs wrote:There’s been a lot of technical discussions on the benefits of push versus pull type suspensions. How the rod is loaded in bump and rebound as well as the loading seen by the outboard end of the wishbone. While the installation stiffness versus weight might vary between the options the main factor is packaging. F1 cars have had front push rod suspensions since the advent of high noses (the Minardi PS01 and Arrows A22 both had a low nose), simply because there was nowhere to package the linkages in a high nose without a poor angle to the pull rod. Pushrods place the parts in a better location for access albeit at a price for Vertical CofG. At the rear the issue has been both a suitable location for the linkages\torsion bars and the third damper (and latterly an inerter), thus atop the gearbox is the ideal solution for a narrow rear end.
This year the need for narrowness is partly negated by the new rules pushing the diffuser 33cm back, leaving space low down to package the linkages etc. However I don’t know how Newey has interconnected the linkages to a third damper and inerter, I guess he has lengthened the gearbox to create space between the engine, clutch and gearbox and passed the two 3rd elements above and below the counter shaft. Access to this lot will be a nightmare, but a sign of true Newey car. Changing torsion bars and dampers will be a floor and gearbox off job.
Allow me to be slightly doubtful here Terry, is there any way you could quantify this load-bearing capacity of the flextures? I seem to remember that when John Barnard first introduced such on the Ferrari in the 90s, there were arguments of them being illegal due to just that capacity?riff_raff wrote:Here's something to consider with regards to pull vs push rods on a modern F1 suspension. A few years back F1 cars used spherical joints instead of flexures for their a-arm attachments. Pushrods were preferred since they could accommodate higher rebound compression forces than slender pullrods. With the flexure joints now in use, the flexure is in effect an additional spring (like the tire sidewall) whose forces are not transferred through the push/pull rod. Thus the suspension spring itself is required to produce less of the total suspension spring force. So a pull rod might be suitable with these lower loads.
