Ferrari SF-24
Unc1eM0nty
Re: Ferrari SF-24
That rake is just wild, like some flaming hot rod detail =D>
Re: Ferrari SF-24
Undercut is enormous from this angle:
It just looks like a fully floating sidepod.
A lion must kill its prey.
SoulPancake13
SoulPancake13
Re: Ferrari SF-24
Something that today's AMUS article referenced is that RB have likely found the "maximum" downforce they can generate before they think porpoising will set in, so to find downforce they have to go in other ways like with their current "evolution" - hence the slimmer sidepods to reduce drag and the profiling of the sidepod like another wing to generate more downforce in the region between the sidepod and floor. Would Ferrari be likely to adopt a similar mentality? Where do people see the room for improvement(bar floor related upgrades)?
bananapeel23
Re: Ferrari SF-24
michl420 wrote:
21 Feb 2024, 13:50
F1NAC wrote:
21 Feb 2024, 13:33
michl420 wrote:
21 Feb 2024, 13:12
Looks like there in no s-duct outlet anymore (Based on one of vanja#66 pictures above).
it is there
CaribouBread wrote:
21 Feb 2024, 09:35
Ferrari raking behind the halo outlet / s duct outlet area
(sorry for the poor image)
https://i.imgur.com/IiV7rhk.png
Based on this picture?!
https://pbs.twimg.com/media/GG2JIi8WYAA ... ame=medium
What exactly is going on in the rear/lower "tunnel" isn't exactly clear from that photo. To me it kind of looks like there is a hole at the bottom of the rear/lower "tunnel" that kicks the air from the S-duct out. I have no clue why they would ever do that, but if it does indeed flow upwards, I'd assume it helps to control the halo losses on top of the cannons.
Re: Ferrari SF-24
SoulPancake13 wrote:
22 Feb 2024, 02:37
Ferrari and Aston Martin have hinted as much for their '24 cars, but there's something else with the floors. It's not about looking for the peak. Many have found there is a peak where porpoising occurs. What the best teams care about is "peak broadening". You need an aero map that generates large downforce numbers across a large range of vehicle attitudes (ride height, yaw). This is precisely the issue that Ferrari have addressed with the SF24 and they and the other teams will keep going in this direction. Rather than chasing peaks, they seek to fill in the lows in the aero map.
Re: Ferrari SF-24
22 Feb 2024, 02:37
The only thing generated there is lift, don't let them fool you :mrgreen: All sidepods used today generate lift and drag, teams are now playing around different designs to optimise outwash for minimal drag and lift penalty. Ferrari specifically has more room to play around and optimise this area since their starting position is basically the least advanced right now.
Andi76
Andi76
445
Re: Ferrari SF-24
22 Feb 2024, 02:37
I completely agree with that. It's a kind of sidepod wing concept. Newey has remembered Nicolo's concept from 2011 :lol:
Vanja #66 wrote:
22 Feb 2024, 08:30
22 Feb 2024, 02:37
The only thing generated there is lift, don't let them fool you :mrgreen: All sidepods generate lift and drag, teams are now playing around different designs to optimise outwash for minimal drag and lift penalty. Ferrari specifically has more room to play around and optimise this area since their starting position is basically the least advanced right now.
Sorry i have to disagree. There was indeed the Sidepod Wing Concept from Nicolo Petrucci, which many people confused with the "double-floor" concept at the time. Here the sidepod functioned like a wing. Even though I don't know it personally and don't value it, I know from a reliable source (from the inventor - Nicolo Petrucci) that these sidepods generated downforce. Even if it wasn't much.
Re: Ferrari SF-24
Andi76 wrote:
22 Feb 2024, 08:35
Sorry that I have to disagree. There was indeed the side-pod wing concept, which many people confused with the "double-floor" concept at the time. Here the sidepod functioned like a wing. Even though I don't know it personally and don't value it, I know from a reliable source (from the inventor - Nicolo Petrucci) that these sidepods generated downforce. Even if it wasn't much.
My bad there, should have been clear that I refer to all sidepods in use today :)
Andi76
Andi76
445
Re: Ferrari SF-24
Vanja #66 wrote:
22 Feb 2024, 08:44
Andi76 wrote:
22 Feb 2024, 08:35
Or my fault for not realizing it :lol: - but don't you think Red Bull's Sidepods are going in that direction? The shape and everything else reminds me a lot of it when you compare it to the STR06.
Re: Ferrari SF-24
AMuS
CaribouBread
CaribouBread
101
Re: Ferrari SF-24
Interesting that the lower SIPS has its own modular carbon panel, will look forward to potential changes to that area :idea:
F1ern
F1ern
16
Re: Ferrari SF-24
CaribouBread wrote:
22 Feb 2024, 11:21
Its four mounting purposes no? To be able to fit the floor to the monocoque.
Vinlarr89
Vinlarr89
Re: Ferrari SF-24
Has anyone got any visibility of gear ratios compared to last year?
Seems that FER is still only achieving 17mph with DRS and RB/ML 20mph, albeit that advantage is better than at this point last year.
I think there’s positives in that there is decent performance, and at face value plenty of opportunity for enhancements to the aero given again at face value looks quite vanilla compared to some of the more again at face value refined designs.
Re: Ferrari SF-24
Fabrega
FDD
FDD
82
Re: Ferrari SF-24
Looks like they have plenty of room to reshape the sidepods.
