jofs89
jofs89
Alonso looking rapid... It is real?
snajam
snajam
Low fuel the car is rapid. Was last week as well, fill it up and it becomes an understeery boat
OnEcRiTiCaL
OnEcRiTiCaL
NAPI10 wrote:
07 Mar 2024, 17:42
diffuser wrote:
07 Mar 2024, 17:10
OnEcRiTiCaL wrote:
07 Mar 2024, 17:02
The car is fast,I mean the potential is there for sure,hope this time they push till the floor instead of waiting for SC.
Even if they did, the degradation here isn't as bad so the times wouldn't fall off as fast.
edit
Bahrain is probably in the top 3 for tire deg. So they have time till they get to the next race with High deg to make adjustments. In the mean time maybe they can get an edge, at low deg tracks, from being able to get heat into their tires easier.
Top speed still sucks...AM will be vernerable on straights.
Bro,you watched the 2023 FP1?lol
Alonsismo
Alonsismo
i can see alonso doing 10 poles and 0 podiums this season
CouncilorIrissa
CouncilorIrissa
Yeah, that's a certified SF23 moment
jofs89
jofs89
snajam wrote:
07 Mar 2024, 19:25
Yeah, but not this rapid. Looks like pole territory at the moment :shock:
They found Beast mode ?????
Alonsismo
Alonsismo
the green bullet
kenji
kenji
Stroll is getting good times as well. The car ist fast, i hope that it isn't just glory running.
Vinlarr89
Vinlarr89
Power is turned down on Ferraris at the moment.
Kamel
Kamel
diffuser wrote:
07 Mar 2024, 16:54
Waz wrote:
07 Mar 2024, 15:30
Alonso did a lot of extra laps compared to those in front of him, something the SF-23 wouldn't have been able to do.
Going to maintain that they aren't maximizing their race by almost always trying to go longer.
But they seem stuck in their ways, instead of just once trying an aggressive option.
Remember Alonso winning at Barcelona in 2013 with 4 stops? They decided to run an aggressive race plan that day.
Tire Degradation isn't gonna be an issue here.
Is it? AMR24 rear wing configuration tells me otherwise
ALO_Power
ALO_Power
How are long runs looking? Seeing Alonso so high up in both FP1 and FP2 gives some hope.
nowaysthatsreal
nowaysthatsreal
Heavy fuel long runs look bad
Xyz22
Xyz22
123
nowaysthatsreal wrote:
07 Mar 2024, 20:07
Quite a lot of deg in this track as well on the mediums. First sector times going up yep.
OnEcRiTiCaL
OnEcRiTiCaL
Xyz22 wrote:
07 Mar 2024, 20:10
07 Mar 2024, 20:07
very bad...:(
