2024 Scuderia Ferrari F1 Team
dialtone
dialtone
123
Cs98 wrote:The result is good but how impressed can you really be? Ferrari had the clear second fastest car here and it wasn't a problem to pass, so the running order worked itself out. Still, if they perform like this (quali) on a weekend where the competitive picture is less divided, they will suffer in the results column.
This is Ferrari weakest track on the calendar and the strategist team you repeatedly called incompetent did instead a great job.
Bad trolling attempt.
Fakepivot
Fakepivot
jambuka wrote:
07 Apr 2024, 09:29
Good race, Ferrari missed opportunity to tell Sainz no fighting. Not sure why only LEC gets told no fighting.
well sainz got told not fighting last year canada.. i think if the pace was some what equal i would agree, but sainz with 10 lap newer tyres its no brainer
JPower
JPower
43
That was as good as it was going to get. Bravo Ferrari.
Cs98
Cs98
37
dialtone wrote:
07 Apr 2024, 09:42
Past tense, they used to be incompetent. They got the results they should've, nothing too impressive about that anymore than RBR getting the 1-2. And you can't keep using the SF23 to determine where the SF24's weakest circuits are. That's illogical, the car is completely different.
Xyz22
Xyz22
124
The potential in race trim was even higher as underlined by Perez and Max in the cooldown room. They were “surprised” by Leclerc pace on the 1 stop strategy which wasn’t the optimal strategy at all (but the right one for Leclerc).
Again he needs to get on top of that outlap in qualifying. The pace in the race is there.
bagajohny
bagajohny
I think LEC had a chance at P2 had not made the mistake while defending Checo. Also Checo was unable to overtake him for two laps in a row. Medium tyres were better than Hard tyres today so he could have extended his first stint a bit further. Because of the mistake he even lost the podium.
Not to say I am unhappy with the result. It is definitely a great result for the team. Ferrari is now clearly second force on the track. But LEC cannot afford such mistakes in championship fights.
dialtone
dialtone
123
Cs98 wrote:
dialtone wrote:
07 Apr 2024, 09:42
I’m not using the SF-23. This track suits RBR particularly well and MCL was stronger here as Ferrari hasn’t had strong fast corner performance so far this season.
This is simply the weakest track so far.
scuderiabrandon
111
bagajohny wrote:
07 Apr 2024, 09:58
That cost him at most a second. The biggest mistake came from not qualifying further ahead.
Xyz22
Xyz22
124
scuderiabrandon wrote:
07 Apr 2024, 10:07
bagajohny wrote:
07 Apr 2024, 09:58
Yep.
This is --- frustrating because he is super quick in the race.
In any event, the overall pace in the race of the car was really strong when you factor in RB brought a significant upgrade.
Vinlarr89
Vinlarr89
Great post race interview from Leclerc. Sounds like he’s really confident that the quali is not a car issue, but work he needs to do to put the car in the right window. But more I’m intrigued by what Ferrari has in the pipeline. There was a bit of a smirk from leclerc suggesting they could be back in the fight later in the season. Looking at the race pace today, the Ferrari looks to be on another level even to RB when it comes to tyres this year, which suggests that some of that could be traded for more performance. RBR are better in the first stints but with more deg, although their drivers suggested that was because of the direction they went in setup to secure pole.
bagajohny
bagajohny
Vinlarr89 wrote:
07 Apr 2024, 10:10
Link?
Cs98
Cs98
37
dialtone wrote:
07 Apr 2024, 10:02
Cs98 wrote:
dialtone wrote:
07 Apr 2024, 09:42
Doesn't mean they are weak here, they were clearly second fastest today and the results reflect that.
dialtone
dialtone
123
Cs98 wrote:
dialtone wrote:
07 Apr 2024, 10:02
Cs98 wrote: Past tense, they used to be incompetent. They got the results they should've, nothing too impressive about that anymore than RBR getting the 1-2. And you can't keep using the SF23 to determine where the SF24's weakest circuits are. That's illogical, the car is completely different.
That’s a totally different argument. This track had the mix of corners that Ferrari drivers themselves said wasn’t gonna suit the car. That they got 2nd best anyway just means the car is that much better than those behind at the moment.
It's quite impressive that Ferrari made a medium-hard strategy work.
And that came on a weekend where the team qualified badly and had to fight traffic to get their "normal" positions.
Really solid, i hope we can find some 4 tenths with the Imola upgrade.
On the negative side, Ferrari was confused why it was so slow in the final sector(which is just the chicane), figuring that out might unlock the car qualy performance.
Mansell89
Mansell89
As a Macca fan here, Ferrari are winning admiring glances from me at the moment.
This is meant to be a strong McLaren track and in spurts, it was. For Ferrari to swat us aside with that superb tyre deg management and such a lovely car balance must surely translate into further race wins this year for the Scuderia.
Upgrades for Aston/McLaren/Merc notwithstanding, the strength of the driver lineup at Ferrari this year I believe puts it in the Constructors Championship fight, IF Perez begins to have his usual mid season struggles.
Bravo on a very well-executed opening 4 races 👏
