venkyhere wrote: ↑21 Jul 2024, 14:04
Emag wrote: ↑21 Jul 2024, 13:30
The flexing wings are a gimmick at best and I don't see how it can help in any way apart from drag reduction down the straights.
At medium and high speeds, by deflecting, the AoA of front wings is reduced - which dials back too-much-front-wheel-bite at high speeds
(the same AoA as you see in pitbox pics, at high speeds, will mean terribly high front end grip) and prevents the aero grip balance from going too-oversteery in medium and high speed corners. In slow corners, where speeds are lesser, the front wings are very nearly having the same AoA as they show in the pitbox pics, which is fine, as it defines the right amount of front downforce and keeps the aero-balance as intended, to rotate the car faster.
In other words, flexi front wings are a dynamic 'aero-balance-adjust' for the car, helping beautifully in slow/med/fast corners by shifting the balance a bit rearwards for high speed and shifting the balance a bit forwards for low speed corners. Which is what the doctor ordered.
Except that each track has a combination of corners which are taken at different speeds. Do you construct a new front wing which physically bends at different speeds to accommodate the track characteristics?
Rather stupid dont you think, especially considering the budget cap.
People like to blow things out of proportion. Things are both much more complex and at the same time much simpler than they seem.
Engineering a front wing which specifically bends the precise amount needed to have a near perfect balance throughout the whole track is just ridiculous honestly. Whats the point of even suggesting active aero if that was possible of achieving at this level.
It was the same discussion at the McLaren car thread about a thin piece of metal wiring connected to the exhaust theoretically being used to utilize the heat from exhausts to expand the diffuser.
Sci-fi talk.
But then again, open discussions are whats the forum is about.
I still hope they clamp down on flex allowances. People will see the pecking order will have no changes and we will move on from this topic and start talking about something else.
