Red Bull RB20
Re: Red Bull RB20
Alexf1
Alexf1
Re: Red Bull RB20
Hi, a while back there was a discussion in the Red Bull team thread about the RB20s relative pace drop since Miami, backed up by this image: Image
There was also someone mentioning a section in TV program GP Confidential about FIA banning the RB20 extra rear damper reservoirs as of Miami:
Could this explain the RB20s sudden drop of pace (and top speed) advantage?
.poz
.poz
50
Re: Red Bull RB20
Alexf1 wrote:
16 Sep 2024, 11:19
Absolutely, a lot more realistic than the differential brake.
those ground effect cars have a huge problem: the center of pressure of the floor moves backward as the air speed increase and the car suffer form under steer
actually there are two way to mitigate this problem:
controlling the ride height (and the rake) with a clever suspension (RB and probably Ferrari in 2024, after Miami RB-Ferrari relative performance remain unchanged with Mclaren ad Mercedes catching up)
with a flexible front wing (Mclaren and then MB): actually i haven't understand if the flexible front wing compensate the under steering generating more load thanks to the wing tips closer to the ground or they actually control the air flux going under the floor
Alexf1
Alexf1
Re: Red Bull RB20
.poz wrote:
16 Sep 2024, 16:09
Alexf1 wrote:
16 Sep 2024, 11:19
Seems like Red Bull had this type of system for quite some time now: https://www.auto-motor-und-sport.de/for ... ison-2022/
No wonder Ross Brawn and Pat Symonds came to take a close look from the very first 2022 pre-season test: https://www.gpblog.com/en/news/105344/f ... elona.html
Indeed there were reports over the winter that Ferrari adopted such a system for 2024: https://scuderiafans.com/f1-sf-24-ferra ... rabian-gp/
Having to do without it after Miami could explain Ferraris drop in performance too.
stewie325
stewie325
Re: Red Bull RB20
Alexf1 wrote:
16 Sep 2024, 16:32
.poz wrote:
16 Sep 2024, 16:09
Alexf1 wrote:
16 Sep 2024, 11:19
I think Red Bull brought a new suspension at Bahrain (the 2nd test) which greatly improved their performance and removed porpoising, so the FIA inspecting it carefully at Barcelona wouldn't have shown them the true picture.
If the story is true, I wonder why it took two years for the system to get banned.
Henk_v
Henk_v
86
Re: Red Bull RB20
Due to my profession, I hold a few patents. One of them explains a certain apparatus and how it works.
In truth it does not work that way at all. The real invention is buried in what the text implies. The true invention is a presumed secondary effect.
Of course the text is written up by experienced professionals, truthful and protects the invention well, but anybody reading the patent will either see a cunning apparatus with doubtful real life application or if tempted to replicate it will be chasing the wrong mode of working.
The point is, how stuff really works and interacts may not be allways obvious looking at te parts, 3D CAD or drawings. Secondary effect may be exploited.
bananapeel23
Re: Red Bull RB20
With Red Bull refusing to do a special livery for Singapore and Austin out of weight concerns. Does this mean that the RB20 is overweight, or are they just so incredibly concerned about car performance that the microscopic change in center of gravity that a few hundred grams of paint would bring over ballast is too much for them?
lio007
316
Re: Red Bull RB20
Alexf1 wrote:
16 Sep 2024, 16:32
.poz wrote:
16 Sep 2024, 16:09
Alexf1 wrote:
16 Sep 2024, 11:19
Is there any possibility that Rob Marshall said "Hey FIA, take a closer look at this and that on the RB20"?
Is this how the business works? Even if it's your ex-Team where you have been part of for more than a decade?
Paa
Re: Red Bull RB20
bananapeel23 wrote:
19 Sep 2024, 13:19
They talk so much about aerodynamic balance being off, that I can only imagine they would like to have as much freedom as possible with playing with ballast. Even if the two are not directly connected, one might help to balance the other?
