2024 Singapore Grand Prix - Marina Bay, Sep 20 - 22
Z-one
Z-one
Re: 2024 Singapore Grand Prix - Marina Bay, Sep 20 - 22
17 Sep 2024, 15:59
FW17 wrote:
17 Sep 2024, 15:46
Are there going to be 4 drs zones?
https://media.formula1.com/image/upload ... re_Circuit
whit 4 drs,2 stop strategy in 544 could be used
Jaeger wrote:
17 Sep 2024, 16:04
17 Sep 2024, 15:59
FW17 wrote:
17 Sep 2024, 15:46
"The FIA has decided to add a fourth DRS zone to the Marina Bay circuit for Formula 1's return to the Singapore Grand Prix."
https://www.motorsport.com/f1/news/fia- ... /10655159/
Yes, the picture that I linked shows the 4 DRS zones. I was not disputing it. There are still only 3 detection points. I assume that means the 4th uses the same detection point as the 3rd.
A lion must kill its prey.
ispano6
154
Another change that the drivers can look ahead to dealing with is the result of a resurfacing job carried out in several areas.
Tyre supplier Pirelli has detailed the track has been relayered between Turn 3 and 9, 10 and 12, and 14 and 17, which should provide a “smoother surface”, according to the Italian marque.
bananapeel23
Vanja #66 wrote:
17 Sep 2024, 10:11
An easy 1-2 McLaren if drivers don't mess up Q3, SF24 won't be a match on a damp track, the car is too gentle on tyres in Q
Singapore is hot and humid though, so they may end up having a slightly easier time than usual, should it end up being a wet race.
bananapeel23 wrote:
17 Sep 2024, 16:22
McLaren is the favourite no matter what. Ferrari performed at 99% perfection in Baku race with Leclerc and they lost to McLaren in one braking zone and that was it
bananapeel23
Vanja #66 wrote:
17 Sep 2024, 16:32
bananapeel23 wrote:
17 Sep 2024, 16:22
Then assuming it's a dry race, Ferrari should be even more likely to win than in Baku, since overtaking on track in Singapore is nearly impossible without a massive pace delta.
Ferrari SHOULD be good in quali here if it's dry, if they start on pole, they're likely to win.
Also let's not forget that Ferrari had comfortably the fastest car in Baku and only lost out due to a questionable overcut call and a stupid mistake from Leclerc during the warmup phase. If you can sit within a second of the driver in front for 30-something laps before your tyres give up, you have a pretty massive pace delta.
venkyhere
venkyhere
16
Wild prediction :
1 Ferrari , 1 Mercedes, 1 Redbull on the podium.
Both McLarens will take each other out (double DNF), and injure the other Ferrari and other Mercedes.
Realistic prediction :
2 Mclarens and 1 Ferrari on the podium. Mercedes in 4/5/6 places. Redbull 7th and 8th.
codetower
bananapeel23 wrote:
17 Sep 2024, 16:58
Vanja #66 wrote:
17 Sep 2024, 16:32
bananapeel23 wrote:
17 Sep 2024, 16:22
I'm not convinced Ferrari had "comfortably" the fastest car on the grid. Leclerc was comfortably fastest on the S, and was fastest on the M, but McLaren was very quick on the H. Ferrari had trouble getting the Hards in the right window, and just didn't have the same pace as McLaren.
But yeah, I can see Ferrari being strong here. My optimistic prediction is 1. LEC, 2. PIA... I think we're witnessing the start of an incredible driver battle for the next couple of years.
FW17
170
17 Sep 2024, 16:06
Jaeger wrote:
17 Sep 2024, 16:04
That is such a dumb circuit layout, even if they have DRS on every straight section it will not make it bearable.
codetower wrote:
17 Sep 2024, 20:49
Sainz was comfortably faster than Piastri on Hards and his gap to Leclerc on this track was 2-3 tenths a lap at least. It was a perfect storm for Ferrari with Leclerc, but they contributed to most of it
Xyz22
Xyz22
123
Vanja #66 wrote:
18 Sep 2024, 08:56
codetower wrote:
17 Sep 2024, 20:49
We must factor in that Piastri is probably the weakest driver in terms of race pace between the top teams (outside european Perez, of course :D ). But I agree Leclerc Ferrari was clearly the fastest package in Baku.
Unless you have over 0.6s delta and significant top speed advantage track position is absolutely king. Dirty air, with these small gaps, is a killer for your tyres and therefore pace.
F1NAC
170
17 Sep 2024, 15:59
FW17 wrote:
17 Sep 2024, 15:46
How long until Singapore becomes first circuit where you can use DRS wherever you want? 😂
Tommy.G
Tommy.G
This circuit should have had this layout since day 1! It makes racing so much better! I remember looking at it through Google Maps years ago and wondering why they don’t just go straight from Turn 14 to Turn 16!
Meanwhile Red Bull was the fastest by over a tenth through the low speed stuff in Baku! The Singapore bumps though may be their biggest problem this time around…
We desperately need a Norris 1st - Verstapen DNF for this championship to come alive at last! Otherwise I don’t see anyone catching Max anytime soon! Not to mention that Red Bull will bring updates in Austin and probably they’ll be back in business…
FW17 wrote:
18 Sep 2024, 05:09
17 Sep 2024, 16:06
Jaeger wrote:
17 Sep 2024, 16:04
=D> =D>
