2024 Mclaren Formula 1 Team
FittingMechanics
FittingMechanics
16
mwillems wrote:
21 Sep 2024, 13:02
Yes it's hard to see that Norris isn't dominating on softs if not mediums. That's fine, it's a hard place to overtake, track position is extremely important. Hopefully the Ferraris and Max can start behind the Mercedes. And fingers crossed Oscar can sort his sh*t out. Not a good showing so far and very little time to get around it now, but we need him up there.
Max had a lot of luck this year. It has to run out somewhere. Why not walls of Singapore.
Emag
Emag
83
mwillems wrote:
21 Sep 2024, 13:02
I just saw the telemetry for Lando's lap on the mediums. Just judging from lowest apex speeds, acceleration and top speeds, the car is heavy and/or lower engine mode compared to Verstappen's and Leclerc's laps on the mediums.
He probably could go a lot quicker on mediums too, if they really wanted to, but I guess it's a bit of a useless run so they did not bother. You usually put the driver on the mediums on high fuel just so he could get a feel for the track/car on multiple laps. Then the lap on the softs is the one that matters to judge the pace.
mwillems
44
Charles losing most time at T1 and T3, T10, T13, T14. Struggling in the slowest corners. Don't think this is tyres to be honest.
-Bandit
mwillems
44
Emag wrote:
21 Sep 2024, 13:07
mwillems wrote:
21 Sep 2024, 13:02
Yeah I wasn't quite prepared to say we were running heavier on meds, but it is on my mind too. I think Leclerc is f*cked, that I feel confident enough to say at this point. I haven't compared to anyone else, but I hope you're right about running heavy. Against Charles though, we are hitting better apex speeds and top speeds are similar.
-Bandit
Emag
Emag
83
mwillems wrote:
21 Sep 2024, 13:07
Don't underestimate the effect bad tire condition can have on laptime. Especially if they were overheating them, you lose so much time almost everywhere. Car refuses to turn, traction is bad, you lose the rear on entry. A good car can look horrible if the tires are not in the right window.
I think they will definitely be closer come qualifying. I don't want to discount Leclerc from the fight for pole yet.
mwillems
44
Emag wrote:
21 Sep 2024, 13:09
mwillems wrote:
21 Sep 2024, 13:07
It's more that it is specific to that type of slow corner and throughout the lap the tyre never comes back, so I think it's something else. Could be tyre pressures I suppose.
-Bandit
FittingMechanics
FittingMechanics
16
Ferrari/Leclerc referred to the stewards for changing pressures. Probably just a team penalty.
mwillems
44
FittingMechanics wrote:
21 Sep 2024, 13:14
Just saw in the Ferrari thread. When was the tyre pressure adjustment? Pre fast lap?
-Bandit
SilviuAgo
Seeing also the onboards from Lando, Charles, Russell and Max, the McLaren seems to have better grip, better traction, more stable through corners and to be more, let's say, "driver friendly". The others have some corners where need to fight with the car, to take slower entry speed or to make notable corrections to steering.
I hope Lando (and even Oscar) can pass Q1 and 2 with a single set of softs and to be able to have best strategy in Q3. Hazard is still available due to a crash or lizzards, so our drivers should avoid what happened in Baku with that yellow flag affecting Lando's Q1 lap.
SilviuAgo
mwillems wrote:
21 Sep 2024, 13:15
21 Sep 2024, 13:14
Leclerc did a fast lap, then complaining about car behaviour and box. A mechanic checked front tires pressure and he was back again but did a +1 lap time till drop off.
mwillems
44
OK so tyre pressure isn't the reason for his slow lap on softs. Hopefully (Sorry Charles), he's screwed.
-Bandit
FittingMechanics
FittingMechanics
16
mwillems wrote:
21 Sep 2024, 13:15
21 Sep 2024, 13:14
After first hot lap. Leclerc complained a lot on the radio, went into pits, they changed front wing and did something with the pressures. Then he did a second lap that fell apart because tires couldn't do a second hot lap.
FittingMechanics
FittingMechanics
16
I can see that Russel improved by 1.7s from his medium run, Norris improved by 2s and Piastri by 1.6s.
Could it be that Mercedes engine was tuned down especially hard for the medium run? It is quite hot in Singapore and maybe they are just being cautious. Could explain big jumps by at least 3 of Mercedes engine cars. Alonso also improved by 1.4s or so. Ferraris and Red Bulls gained about 1s.
mwillems
44
Given that Piastri improved by 1.6, I just have a feeling Norris is on it today.
-Bandit
geogate
geogate
the tyre pressure thing will be a bit concerning for ferrari fans - I was suspecting a bit of gamesmanship until they did something last minute that clearly was going to get them in front of the stewards - looked like some low key panic going on
