Bib parc fermé ride height trick
Stea1th
Stea1th
Re: Bib parc fermé ride height trick
Helmet say something about they were also going to the fia about some other trickery that McLaren was doing besides the front wing? I remember trading a quote about him talking about it and saying it’s not only the front wing.
pantherxxx
pantherxxx
It's probably a nothingburger then. The Mclaren version would have made sense. If a team could adjust ride height for real, they would have a huge advantage, and Red Bull doesn't have that.
pantherxxx wrote:
17 Oct 2024, 18:09
This could theoretically explain why Lando Norris was able to be 1 second per lap faster than Verstappen at the beginning of the Singapore GP. McLaren’s car would be perfectly set up to handle the heavy load, while other teams, forced to compromise, might struggle with balance, grip, and tire management early on.
At the start of the race, with a full fuel load, most teams would be using a compromised setup that balances qualifying performance with race performance. However, if McLaren (using this trick) could start the race with an optimal setup tailored specifically for a heavy fuel load (via ride height adjustments), they could achieve better stability, downforce, and grip from the very first lap.
As the race progresses and fuel burns off, the car becomes lighter. A lower ride height would once again be optimal for aerodynamics. Since McLaren’s ride height was raised for the heavier fuel load, they might lose the aerodynamic edge once the car becomes lighter in the second stint.
(Again, this is just speculation, I'm not accusing anyone).
If it's Red Bull then it would be this but backwards, Red Bull punches above it's weight in qualifying.
peewon
If the FIA is immediately jumping on something, you can be rest assured its not Mercedes or Mclaren doing it.
Delasoup
Delasoup
As concerns arose that such a system could be used in parc ferme conditions, do you believe there is a way/will for the FIA to lookback at the team data or video footage to determine if the said contraption was ever used illegally?
scuderiabrandon
111
chrisc90 wrote:
17 Oct 2024, 19:19
"No evidence yet, however - the FIA ​​also states - and Red Bull also strongly denies it."
When you have multiple teams saying you did it, it is hard to look past it. The fact that there is no evidence only means the FIA can't punish them, it can however potentially stop them from doing it again.
scuderiabrandon
111
pantherxxx wrote:
17 Oct 2024, 19:22
Just because they have other problems doesn't exclude them from being the perpetrators. Very often the bad outwieghs the good.
“It only makes sense when it is not the team I support lol” :lol: :lol: :lol:
chrisc90
scuderiabrandon wrote:
17 Oct 2024, 19:40
chrisc90 wrote:
17 Oct 2024, 19:19
Yet its been quiet until today. If other teams suspected it, of any other team, I imagine there would be someone to shout about it.
pantherxxx
pantherxxx
17 Oct 2024, 19:42
pantherxxx wrote:
17 Oct 2024, 19:22
Who said anything about which team I support? I'm a Ferrari fan by the way. From a logical standpoint, it was Mclaren who made sudden huge performance gains this season, and not Red Bull. So in the light of this, it seems more likely that it's just an accusation against Red Bull, than a real serious thing.
scuderiabrandon
111
chrisc90 wrote:
17 Oct 2024, 19:44
17 Oct 2024, 19:40
chrisc90 wrote:
17 Oct 2024, 19:19
Because the exclusive article only dropped midnight yesterday, lol? Ofcourse it was quiet until today. In that article, it states discussions have been taking place since Singapore. In the same article, it states that multiple teams pointed to the same suspect.
scuderiabrandon
111
pantherxxx wrote:
17 Oct 2024, 19:47
17 Oct 2024, 19:42
pantherxxx wrote:
17 Oct 2024, 19:22
You are under the assumption that they haven't been doing this the entire season. Like I said, bad development could be outweighing the gains from this, that doesn't make it a 'nothingburger' because changing stuff under parc fermé is a clear, and I mean crystal clear, breach of the regulations. In fact, we shouldn't even be discussing the effectiveness when it is straight out illegal to change stuff under parc fermé.
Now saying there is no evidence is the truth, there is nothing, but that only means they can't get DSQ'ed from past races. However, now that there has been light shed on it, it can stop them from doing it in future races, where you would see the effects of it given the measures put in place are sufficient at stopping them from doing it.
Venturiation
Venturiation
101
17 Oct 2024, 19:52
pantherxxx wrote:
17 Oct 2024, 19:47
17 Oct 2024, 19:42
But is this just discovered now or was it the thing that changed in Miami but only made public now
scuderiabrandon
111
Venturiation wrote:
17 Oct 2024, 19:58
17 Oct 2024, 19:52
pantherxxx wrote:
17 Oct 2024, 19:47
From autosport article
"It is understood teams have been alerted to the possibility of this happening through the design details of all cars needing to be uploaded to FIA servers on open-source components – which all competitors have access to."
To me, it suggests that this is a system which doesn't require a manual adjustment from a mechanic, so a lever or switch system in the cockpit. Having someone do it manually would be incredibly obvious and suspicious so I don't by into the idea that its a manual input.
Teams miss things, just like they missed Mclaren's rear wing trick, which took a fan (me) to expose it before action was taken.
lio007
320
Can anybody explain the part "...and points out all design details are uploaded to the FIA server that all teams have access to"
Do the teams really have access to designs of other teams?
the EDGE
the EDGE
68
lio007 wrote:
17 Oct 2024, 20:06
https://twitter.com/redbulletin/status/ ... 02QOw&s=19
Read this… https://www.the-race.com/formula-1/f1-2 ... %20designs.
