There was a bit before that with RBR mechanics showing the tool being used too. Its not something that can be done sneakily .
Easiest way to be sneaky would be to do that completely in the open under the pretense of adjusting pedals.Watto wrote: ↑18 Oct 2024, 21:15There was a bit before that with RBR mechanics showing the tool being used too. Its not something that can be done sneakily .
Even Ted who tend to be quick to jump on Red Bull said he things it is nothing having seen it been demoed.
It does look simple and easy to make setup changes. Don't know though how it compares to how other teams do it
Where is that fact? That's not confirmed. There is just accusation...scuderiabrandon wrote: ↑18 Oct 2024, 00:37Seemingly no one wearing an RBR shirt gets that just because you claim it is not very effective does not excuse you from the fact that it could be used to make changes when strictly prohibited not to, which is most likely what it was used for.pantherxxx wrote: ↑18 Oct 2024, 00:23Max on the T-tray 'trick' ban: "We didn't even discuss it in the briefing."
"It's a public, right? Everyone can see it. For us, it was an easy tool when the parts were not on the car. It was easy to adjust the car, but once the whole car was built together, you couldn't touch it.
It doesn't change anything. When I read it, I thought other teams were using it. Then I found out it was about us, we didn't even discuss it in the briefing."
Exactly what I thought....put an enormous extension on a powered ratchet to make it look hard to hide. Both unnecessary!Raleigh wrote: ↑18 Oct 2024, 21:38Easiest way to be sneaky would be to do that completely in the open under the pretense of adjusting pedals.Watto wrote: ↑18 Oct 2024, 21:15There was a bit before that with RBR mechanics showing the tool being used too. Its not something that can be done sneakily .
Because there is no way the FIA scrutineer can see exactly what a mechanic is working on while reaching down into that hatch with a little 1/4 hand ratchet.
I can promise you, the tool Red Bull demoed is definitely not the only way to make that adjustment.
Wtf? Where are you hear such nonsense?XRayF1 wrote: ↑18 Oct 2024, 11:22If I may add further to this, I despise having discussions about 'not having gained an advantage' after a team having themselves admitted breaching the rules.FittingMechanics wrote: ↑18 Oct 2024, 10:47If we want to give benefit of the doubt to Red Bull it would be great to know how load of the spring is changed on other cars. Is it much more complicated or just a matter of doing it outside of the cockpit (below the car). If it is simple to change it on other cars and there is no real benefit of putting it inside the cockpit, then we probably shouldn't trust Red Bull story that they never used it in parc ferme.-wkst- wrote: ↑18 Oct 2024, 10:00Schmidt (AMuS) writes that McLaren denigrated RBR at the FIA, some sort of revenge for the rear wing saga in Baku.
A cover in the cockpit must be removed and a tool is necessary to change the initial load of the spring.
Not possible in the forbidden time without notice (parc ferme).
Tools in the cockpit is probably done for various other things (pedal adjustment for example).
Whatever the theory, having an ability to run slightly different setup in qualifying compared to the race is a benefit. If what you say RB20 maybe is not the car that would gain from such a change as much as others, but they would still gain something. That much is blatantly obvious. This is just the nature of having a fixed setup after qualifying. You need to make compromises. Being able to change a few things means less compromises are needed.Vanja #66 wrote: ↑18 Oct 2024, 10:38
This makes absolute sense, RB20 is absolutely not a car that is capable of exploiting elevated or softer front bib with their excessively stiff front end. If they exploited this in Q at least, they would have been able to run a lot better over kerbs and bumps - but they can't due to inherit suspension limit, in which case running a bib tilted up is probably even hurting you. McLaren's softer front end, eg, would be perfect to exploit this kind of device and they do have the Q speed and the best Q/R pace balance of all cars.
On the other hand, neither RB18 or RB19 were better in Q than R, so having such a change available on their cars would have resulted in a lot better Q3 performance in two previous seasons. I never suspected RB to be the targeted team, they simply have too many issues that such a setup change between Q and R would compensate.
Either I do have rules, or not.
FIA by their interpretation have found RB being in breach of this regs, which RBR have confirmed.
Who can actually say that it has not contributed to the performance of the car?
Nobody but RBR, and the statement they made about not having used it between Q & R may be believed, or not.
Bottom line to me, why has RBR brought the device into the car as it is, if it not to gain an advantage?
First of all, it need to be proven that it can be changed. Then, it need to be proven that it was/is changed under parc ferme. Until that, you can only bark...FittingMechanics wrote: ↑18 Oct 2024, 12:00Can we agree that being able to run two different setups in qualy and race is usually beneficial? We can speculate as much as we want and think how much it could help, but I think the basics of it are simple. If you are able to make a change in parc ferme, that is almost certainly an advantage (or at least opportunity for an advantage).Vanja #66 wrote: ↑18 Oct 2024, 11:57If the idea is to raise the front bib for Q setup, this will be done primarily to set the car up for riding lower than bumps and kerbs would "allow" and the negative aspect would be creating a small gap that will increase drag and lift locally. If you can't ride bumps and kerbs for other reasons, you'd probably only get the negatives out of it.
If you have an overall setup for maximum cornering speed in high-speed corners (ie you are already running at the lowest attitude) this kind of front bib geometry won't help you running lower since your car is already as low as possible. It can only bring the negatives of local lift and drag increase.
All of this is based on an assumption of very flexible floor and plank and both of those grey areas have already been addressed in recent years
Maybe in some cases you don't need to make a change because it's perfect as is, but for things like ride height which are affected by the weight, I think it doesn't work that way.
"Could" “most likely” is not assertive language. It's speculative, speculation can not lead to accusations.senja wrote: ↑18 Oct 2024, 21:39Where is that fact? That's not confirmed. There is just accusation...scuderiabrandon wrote: ↑18 Oct 2024, 00:37Seemingly no one wearing an RBR shirt gets that just because you claim it is not very effective does not excuse you from the fact that it could be used to make changes when strictly prohibited not to, which is most likely what it was used for.pantherxxx wrote: ↑18 Oct 2024, 00:23Max on the T-tray 'trick' ban: "We didn't even discuss it in the briefing."
Reminded me of this...thestig84 wrote: ↑18 Oct 2024, 21:45Exactly what I thought....put an enormous extension on a powered ratchet to make it look hard to hide. Both unnecessary!Raleigh wrote: ↑18 Oct 2024, 21:38Easiest way to be sneaky would be to do that completely in the open under the pretense of adjusting pedals.Watto wrote: ↑18 Oct 2024, 21:15There was a bit before that with RBR mechanics showing the tool being used too. Its not something that can be done sneakily .
the fia could check old garage footage broadcasted to see if it has ever happened on cameraRaleigh wrote: ↑18 Oct 2024, 21:38Easiest way to be sneaky would be to do that completely in the open under the pretense of adjusting pedals.Watto wrote: ↑18 Oct 2024, 21:15There was a bit before that with RBR mechanics showing the tool being used too. Its not something that can be done sneakily .
The FIA has a camera right above the car recording everything being done while in the garage.Quantum wrote: ↑18 Oct 2024, 22:24Reminded me of this...thestig84 wrote: ↑18 Oct 2024, 21:45Exactly what I thought....put an enormous extension on a powered ratchet to make it look hard to hide. Both unnecessary!Raleigh wrote: ↑18 Oct 2024, 21:38
I can promise you, the tool Red Bull demoed is definitely not the only way to make that adjustment.![]()
https://twitter.com/NotBrockPierson/sta ... 8568730642
Do Liberty film the cars as they're being race prepped? Or are there screens in place prior to cars leaving the garage?
Be interesting to know, as even on the grid we see mechanics of all teams reaching into the cockpit and footwell before the drivers get in.
