Williams is still using the older pull-rod suspension from Mercedes, as Vowles said Mercedes was too late on informing them of the final push-rod/gearbox specification and didn't want to compromise design of the 2024 car.laspeorasdeaston wrote: ↑21 Oct 2024, 10:44On a "positive note", they are testing 2025 parts on the 2024 chasis so at least they are already gathering data from what's wrong or right. Also, I relate to you guys, we need to see how the team upgrades the '25 car with the new WT. There must be something wrong with Mercedes WT because they had also quite the bad upgrade package here at COTA. Also, I believe their rear suspension is a limitation, thought if a smaller team like Williams is using it and its ahead of us, so it's no excuse or justification.
As bad as Mercedes is, that car is light years better than the Aston Martin. Sauber is much closer to us than Aston Martin is to the 8th best car (look at the race pace stats).
