Yeah, no, that aint happening
"Air" contents varies by weather and location. How does FIA define "air?" it must have some limits on the normal contents.Sergej wrote: ↑05 Nov 2024, 20:11I don't doubt this practice is illegal (I used the wrong word "loophole" previously), I doubt anyone would be able to prove someone did it in past events.Vanja #66 wrote: ↑05 Nov 2024, 18:5210.8.4 Treatment of tyresSergej wrote: ↑05 Nov 2024, 18:22Doubt it, this loophole, if it was real, will be closed by Pirelli who'll enhance supervision, and for past events you can't prove anything anymore, so no ground for official protest; I mean they did not even protest McLaren's Baku win with a full screen video showing a 2nd DRS lol
a. Tyres may only be inflated with air or nitrogen.
b. Any process the intent of which is to reduce the amount of moisture in the tyre and/or
in its inflation gas is forbidden.
c. A complete wheel must contain a single fixed internal gas volume. No valves, bleeds or
permeable membranes are permitted other than to inflate or deflate the tyre whilst the
car is stationary.
https://www.fia.com/sites/default/files ... -04-25.pdf
However anyone spins it, it's quite clear what rules define as legal and illegal. Think I saw there was also a TD introduced to close a loophole after RB experimented with water inside tyres years ago, I imagine rules have been rewritten since.
Very good analysis, thanks for that. It does indeed fit like a glove, I always thought it was very weird how often mclaren are nowhere in the start of races, and suddenly they become 1s a lap faster than anyone else, and can extend stints easily.Vanja #66 wrote: ↑05 Nov 2024, 15:59As I previously noted here, it fits very well as a "missing" puzzle on how McLaren operates their tyres in the race. Mediums in the first stint cooled down in this method would need slower laps initially and picking up the pace and even over-pushing them to heat up the carcass and make the water evaporate. At the same time, you extend the stint and lose minimal time compared to cars that are already on new Hards. Going 5-10 laps longer allows you to push like mad on Hards and you suspension geometry has no problem heating them up, even if they are harder to heat up than Mediums - because your Mediums are artificially cooled down. In the final 30-40% of the race you can be much faster than anyone else ahead, which is exactly what consistently happens with McLaren.organic wrote: ↑05 Nov 2024, 14:50Formu1a Uno reports that red bull are not the only team that suspect McLaren did this
The latest case concerns McLaren's use of Pirelli compounds, a suspicion fueled and pushed by Red Bull but which has also found allies in other teams.Also the amounts in question are less than 10ml, not large quantities that would affect the unsprung mass considerably as speculated heresome teams strongly suspect that in Woking they had put water inside the tire via the inflation valve
Recommend reading the full articleAccording to what Formu1a.uno learned in the last few hours, we are talking about milliliters , therefore very small quantities of water, considering that a single ml would allow a decrease of a few degrees in the temperature at the heart of the tire.
https://formu1a.uno/it/acqua-nelle-gomm ... -ha-prove/
Formu1a Uno going into this depth on the subject suggests to me that Ferrari believe that this idea holds some water
what 'improvement in thermal conductivity' does the graph show ?PlatinumZealot wrote: ↑05 Nov 2024, 22:26... At 80 degrees C air can hold 8 grams of water per cubic meter at 100% Rel humidity so it's not much to get into a tyre.
Add to this the improvements in thermal conductity (note convection will come into play more) but conductivity also important at the boundary layer.
https://i.sstatic.net/aj3bh.png
Being slow(er) at the start is every team's strategy to preserve tyres when the car is heavy and slow so you can't utilise downforce as much as you can later on. McLaren being very slow is more often the case when they are already behind. When they are in free air, they typically run as fast as the next best team and again - drop everyone in the final stint
The Race, in their video on this state that normally other teams will admit to suspicions off the record, yet none have in this instance, with only Red Bull saying anything.organic wrote: ↑05 Nov 2024, 14:50Formu1a Uno reports that red bull are not the only team that suspect McLaren did this
No, because I work in an industry where if something like that was going on, people's lives would be at risk.Farnborough wrote: ↑06 Nov 2024, 19:50Papayafan481, ever been in a management team when something that is likey to be potentially serious, in repercussions, has been going on ?
Then has to be sorted out in some way.
Nobody will want to get near this one, for many reasons. Put bluntly, some managerial levels won't be aware of some things at lower levels
Conversations like "I don't know what's been going on in OUR team, but tell me now that we will never be involved in something like that in future races" do happen. It's a way of a senior manager severing the responsibility line, such that they won't be caught or associated with such behaviour from here on .....
Noted silence, from any direction, prevents awkward questions being faced.
Then everyone moves on ..... to the next whisper
PapayaFan481 wrote: ↑06 Nov 2024, 21:55No, because I work in an industry where if something like that was going on, people's lives would be at risk.
And your comment does not address the fact that Pirelli and the FIA investigated and found NO evidence to support Red Bull's conspiracy theory. Mind you, passing tests and inspections seems only to serve to strengthen some McLaren haters' belief that they are cheating.
There is only 1 team that we KNOW was doing this because they admitted as much - Red Bull. Has anyone checked their tyres??
https://formu1a.uno/it/acqua-nelle-gomm ... -ha-prove/As explained by Mario Isola, "it is impossible to check the tyres of the previous rounds, because the checks should be done at the moment. We would certainly not find water but we could analyze the humidity levels found inside the tire."
https://www.gpblog.com/en/news/311730/r ... ering.htmlAfter the race, Red Bull's team principal, Christian Horner decided to keep his answer brief about the matter. "No comment," the Briton said.
