2025 Aston Martin | Aramco F1 Team
-wkst-
-wkst-
Re: 2025 Aston Martin | Aramco F1 Team
https://racingnews365.com/aston-martin- ... t=13917180
Sounds like the new wind tunnel is in use now, but I am still a bit sceptical, if that’s really the case or just an assumption of this site.
KimiRai
KimiRai
258
-wkst- wrote:
30 Jan 2025, 22:16
The construction of the first new wind tunnel to be built in 20 years for F1 testing purposes was completed in the second half of last year. It was then passed onto Aston Martin to begin the commissioning phase, which has now been completed.
It means for the first time since the Silverstone-based marque was once known as Force India almost two decades ago, it is using its own development facility, rather than relying on the Mercedes wind tunnel at Brackley, nine miles away.
Interesting! Yeah it would be good if some other source confirmed it so we have more certainty. In theory from what was said previously, it was about to be finished around this time or a bit later.
Sherrinford
Sherrinford
KimiRai wrote:
30 Jan 2025, 23:37
-wkst- wrote:
30 Jan 2025, 22:16
If true, it's a great news and almost 1 month before the Bahrain tests
Sherrinford wrote:
31 Jan 2025, 00:41
KimiRai wrote:
30 Jan 2025, 23:37
-wkst- wrote:
30 Jan 2025, 22:16
You'd think that they'd still use the Merc WT primarily. With duplicate tests on their own WT to compare for a time.
-wkst-
-wkst-
KimiRai wrote:
30 Jan 2025, 23:37
-wkst- wrote:
30 Jan 2025, 22:16
As I said I am still a bit sceptical, as there are no direct quotes of Krack that they use it now. The quotes of Krack are all about the future and not the presence. Naturally some AMR twitter fan accounts present it already as a fact, premature as often with no double check...
Reading a lot of articles about AMR in the winter break, you notice how often (especially click-bait sites) use quotes, which were already made at the season final in Abu Dhabi, presenting them as they were talking to the person just currently.
But February was obviously the target (Krack in Abu Dhabi: "in 2-3 months").
collindsilva
collindsilva
-wkst- wrote:
31 Jan 2025, 08:40
KimiRai wrote:
30 Jan 2025, 23:37
-wkst- wrote:
30 Jan 2025, 22:16
It is very quiet from the team, no statements on the car developments or the Wind Tunnel. So we can expect some surprises, Good or bad, fingers crossed.
ispano6
153
diffuser wrote:
31 Jan 2025, 04:22
Sherrinford wrote:
31 Jan 2025, 00:41
KimiRai wrote:
30 Jan 2025, 23:37
Why not leverage Honda's HALO wind tunnel, which has been in commission for over 2 years and has been used for Indycar and WEC. It should be capable of providing correlation data of both WTs and possibly an avenue to not count toward aero time if Honda is comparing data of previous year cars.
Sherrinford
Sherrinford
ispano6 wrote:
31 Jan 2025, 10:30
diffuser wrote:
31 Jan 2025, 04:22
Sherrinford wrote:
31 Jan 2025, 00:41
If it's already difficult with two galleries, how do you think with three?😂
FNTC
FNTC
Part 2 of the Newey interview:
KimiRai
KimiRai
258
Mark Hughes thinks the Honda comments were lost in translation (paywall so here's the full article)
The key reason Honda's engine 'struggles' are lost in translation
Honda says it's struggling with 'technically challenging' 2026 Aston Martin power unit but Newey and Stroll shouldn't worry just yet
Comments by Honda Racing Corporation boss Koji Watanabe at the recent Daytona 24 Hours that the company is struggling with development of its 2026 F1 power unit for Aston Martin have sent alarm bells ringing through F1 – and potentially for Adrian Newey who officially starts on March 3.
Speaking to journalists, Watanabe is quoted as saying, “We are struggling. Now we are trying our best to show the result next year. Everything is new. The [electric] motor is a new 355-kW, very compact one we need.
“Also the lightweight battery, it’s not so easy to develop. And also the small engine with the big power. Everything is very difficult, but we try our best.”
But these comments are probably best viewed through a ‘Lost in Translation’ lens. What Watanabe seems to be describing is just how technically challenging the new PU formula is, especially around the electrical motor and battery which have been conceived to deliver around double the power of the existing F1 electrical motors. If it was easy in these formative stages, it would suggest you’ve probably got something wrong – that it’s going to be too heavy or too bulky or if those targets are achieved, then the worry will be whether it’s competitive on power.
This is new technology and everyone is stretching to find what the defining limits are. It’s one thing to set targets and meet them, quite another to know if you’ve set the right targets. This is always how it is at the beginning of a new formula.
So, based on decades of observing this sort of thing, I’d say those comments do not mean what they are being interpreted as meaning. I’d say, it’s Watanabe’s second language and he’s striving to get across the inherent extent of the ‘challenge’ of the whole process. In the early stages of any tough challenge, it will by definition be a struggle. Similar ‘struggles’ you can be sure will be taking place at Ferrari, Mercedes and Red Bull to greater or lesser degrees. Furthermore, development in these early stages tends to progress in steps as breakthroughs are made. It is rarely linear. Each breakthrough made can completely change the ranking.
Where each of the PU manufacturers believe they are can only be an internal measure at this time. The natural behaviour for any properly competitive F1 engineer at this stage will be to assume that you are not ahead, that you may be behind and that you must continue striving hard to find the secrets. Any engineer saying, ‘Oh, we’ve cracked it,’ would be ridiculed for not understanding the extent of the challenge. Because the company up the road may have cracked it 10 times better than you. Competitive paranoia drives the sport forward.
But the way these things work, just because a comment could be interpreted in a way which would make a bigger news splash inevitably means it will be. So Watanabe’s comments will for certain have generated headlines suggesting that Honda is deep in trouble with the programme, maybe even manifesting the ghost of the company’s initially disastrous hybrid motor of 2015 and perhaps how this is potentially awful news for Aston Martin’s future prospects with its ’26 Adrian Newey wonder car potentially stymied by a feeble motor.
Forget it all. It’s just noise.
https://www.motorsportmagazine.com/arti ... anslation/
We'll see next year I guess. For now 2025 is right ahead and it's important still.
Sasha
Sasha
63
HRC Leaders words was Lost in Translation.
He was just explaining how hard a challenge it's going to be not that Honda is having problems. This is one of the reasons the Japanese do not like to talk to the Western press.
RedNEO
30
Sasha wrote:
31 Jan 2025, 17:05
Especially during the off-season. They have been going clickbait crazy this winter especially around this team. In a way it’s flattering that Aston is getting all the eyes on them.
ispano6 wrote:
31 Jan 2025, 10:30
diffuser wrote:
31 Jan 2025, 04:22
Sherrinford wrote:
31 Jan 2025, 00:41
At this point, the Merc WT is in phase out mode. Probably the last year of Merc Tunnel use. What would be the point in switching when you're already all setup at Merc WT?
Plus, they've been using the Merc WT for several years. It is your baseline. The Honda tunnel would just be another new WT that they would need to compare against the baseline.
RedNEO
30
diffuser wrote:
01 Feb 2025, 13:02
ispano6 wrote:
31 Jan 2025, 10:30
diffuser wrote:
31 Jan 2025, 04:22
I remember watching a video about Mercs WT and they basically switched to using a smooth belt to not have to swap it out as frequently.
It was speculated that it being a smooth surface has some advantages like cost. One major disadvantage is it apparently throws off correlation leading to them getting wildly good results that dont match reality, due to the inconsistent surfaces in real life not being a match for their smooth belt hence the zero pod disaster.
RedNEO wrote:
01 Feb 2025, 15:03
diffuser wrote:
01 Feb 2025, 13:02
ispano6 wrote:
31 Jan 2025, 10:30
Again, AM isn't using the Merc WT in 2025 Cause it's good or bad. They're using it because it's what they have been using in 2024. It's a base for comparison for the AM WT, baseline.
