Paa
bluechris wrote:
22 Apr 2025, 23:09
Paa wrote:
22 Apr 2025, 22:17
Jambier wrote:
22 Apr 2025, 22:10
Why should Russel go to RBR?
Current Red Bull isn’t better than the Mercedes and we all feel that 2026 will be a disaster for Red Bull
I don't think Russell particularly wants to go to RedBull, but it might be his best option if he finds himself out of Mercedes.
Why RB will want Russel really? I mean what he has shown in comparison to Max and i don't speak for championships now. He is above average and that's it, Max is a generation talent and can only be replaced with an equal or a bit less equal like Leclerc for example.
I really don't get all the praise for Russel really and i like the guy but he needs to show some exceptional driving to up his status.
I don't think Red Bull particularly wants Russell, but he might be their best option if they find themselves without Max.
DDopey
DDopey
22 Apr 2025, 22:16
There’s no indication that Max is leaving Red Bull even if his contract allows him to do so.
Horner has been overhyping the car, despite Max’s concerns. There’s a clear difference between their opinions.
In that frame, I think the car isn’t good. The difficulties Yuki has with it, coupled with the challenges Max has had in practice, suggests that Max is right about the car’s performance.
DDopey wrote:
23 Apr 2025, 02:33
22 Apr 2025, 22:16
I don’t think there is disagreement about the cars issues. Horner’s role is not the same as Max’s. Horner has a job to maintain morale by praising the work that is being done, and to make Red Bull look good in the media by hyping the small wins and defending his drivers no matter what.
A lion must kill its prey.
The car looked quite good in the last stint from onboards, especially in the slow corners ( T1 and T2 and last corner). All over the curb in T2 in that stint. On Friday it was not like this. The car seemed softer than usual.
DDopey
DDopey
23 Apr 2025, 07:13
The car looked quite good in the last stint from onboards, especially in the slow corners ( T1 and T2 and last corner). All over the curb in T2 in that stint. On Friday it was not like this. The car seemed softer than usual. This is Mclaren-esque :lol:
https://i.postimg.cc/QdYLptyf/image.png
We will see, I think Jeddah was just a combination of Max, setup luck and track.
FittingMechanics
FittingMechanics
langedweil wrote:
22 Apr 2025, 03:50
Proper analysis from you, Vanja !
Personally I really care more about the fact the RBR could well follow the McL, but I agree with the issue of the FIA inconsistency and dumb/blunt reasoning.
https://twitter.com/aerotechvh/status/1 ... 00AXBCFwjw
Looking at Palmer's analysis on F1 TV it seems that F1 Tempo traces are not accurate, or at least not for the first lap. Maybe the issue is that because Max is slightly ahead, he brakes slightly earlier by distance from his starting spot but that effectively they brake at the same position. In the Palmer video he shows that Max carried more speed through that corner than he did on Q3 pole lap.
pantherxxx
pantherxxx
23 Apr 2025, 07:13
I read that the weight distribution change Red Bull introduced with their Jeddah update allowed them to run softer suspension settings, which the car hadn’t worked well with before. It definitely looks better on track now.
Sergej
interesting video
marcel171281
marcel171281
30
FittingMechanics wrote:
23 Apr 2025, 08:23
Which makes sense, because on single push laps they sacrifice T1 for a good exit off T2, so they carry more speed on the straight after T2.
Rodak
Rodak
37
pantherxxx wrote:
23 Apr 2025, 10:33
23 Apr 2025, 07:13
Well, they couldn't change weight distribution much, as front/rear weights are mandated by regulation. Article 4.2 from the 2025 Technical Regulations:
With the car resting on a horizontal plane the mass measured at the front and rear axles must
not be less than the mass specified in Article 4.1 factored by 0.446 and 0.539 respectively at
all times during the Sprint Qualifying practice and Qualifying sessions. Rounding will be to
nearest 0.5kg.
pantherxxx wrote:
23 Apr 2025, 10:33
23 Apr 2025, 07:13
That’s interesting because softer settings also helps with tire degradation.
On that point again, I also noticed looking at the helmets of each driver during the race that Max’s helmet didn’t move up and down as much as some of the others (Mclaren, Ferrari). It was hard to understand whether the track was bumpy or the other cars were bouncing from the aerodynamics.
marcel171281
marcel171281
30
Rodak wrote:
23 Apr 2025, 16:43
pantherxxx wrote:
23 Apr 2025, 10:33
23 Apr 2025, 07:13
nearest 0.5kg.
Yep, so they must be talking about weight distribution at a non-horizontal plane. Or in other words, how the load shifts under motions, like dive, squat and/or roll.
Rodak
Rodak
37
marcel171281 wrote:
23 Apr 2025, 17:28
Rodak wrote:
23 Apr 2025, 16:43
pantherxxx wrote:
23 Apr 2025, 10:33
nearest 0.5kg.
I suppose they could change the side to side c.g. depending on what were the most critical turns, similar to tire stagger for Indy oval races; I seriously doubt they would raise the c.g.
Paa
Rodak wrote:
23 Apr 2025, 16:43
nearest 0.5kg.
There is literally infinite way of allocating the weight within the car's 3 dimensions while meeting above criteria.
Sergej
I saw Autoracer live and Italian commentator Matteo Bobbi said:
"Red Bull told me that after Spain McLaren will be nowhere, Max is saying off records that if he is within 10 points from McLaren by Barcelona, he's gonna win the title; they are 100% sure McLaren will be hit by the TD; on the other hand, McLaren told me that for them it won't change a thing"
the puzzling thing, according to him, is that both parties are 100% sure of their ideas, so someone is going to be very disappointed come Barcelona.
