ISLAMATRON CRIES BLOODY MURDER AGAIN!!!
I doubt it. The front-end of the Red Bull will be what most teams will be copying like crazy and trying to work from if they feel that their front-end in 2009 just didn't work i.e. Ferrari's. The pull-rod system was something Red Bull had to package up the chassis in a rather specific way. It's going to a blind alley for teams to copy that I think because it implies a lot of other unseen things.ISLAMATRON wrote:Any ideas if any of the other teams will copy RBR's pull rod rear suspension?
Hmmmmmm. You must have been hit by one of you think that's germane to the discussion.timbo wrote:Felipe was hit by a spring.
Does that count as "really wrong"?
Wouldn't a pull-rod suspension make it more difficult to implement an adjustable suspension height, as per the rumored Renault suspension? If so then any CofG benefits would be outweighed by the aero deficit of ever changing ride height as the fuel load comes burns off.n smikle wrote:For other teams that pull-rod could be worth implementing if the designers are up to it. Lower CG is always welcome. Some people say the pull-rod suspension was getting in the way of the double diffuser, but that's not what I saw in the pictures of the RedBull's underside! There were two fully developed scoops underneath; the springs and shocks were probably neatly placed ahead and in between of the scoops. I don't even know how far ahead those shocks were placed, whether up to underneath the engine or just under the transmission is a guess for me. I won't write off a pull-rod suspension on the new Ferrari for sure.
I don't think you can "adjust" the ride height during the race, when that would be seen as a movable aerodynamic device?Astro1 wrote:Also the Gazzetta article suggests that Ferrari have designed a suspension system that will minimized ride height changes as the car gets progressively lighter throughout the race. Would a pullrod make this possible.
EDIT - didn't read properly.xpensive wrote:I don't think you can "adjust" the ride height during the race, when that would be seen as a movable aerodynamic device?Astro1 wrote:Also the Gazzetta article suggests that Ferrari have designed a suspension system that will minimized ride height changes as the car gets progressively lighter throughout the race. Would a pullrod make this possible.
What Ferrari could have developed sounds more like a very progressive load/deflection ratio minimizing the difference in ride height from vertical load, but that is hardly anything new?
