wesley123 wrote:myurr wrote:Pierce89 wrote:It isn't illegal to design spokes like a fan blade
Of course it is - movable aerodynamic surfaces are banned. Otherwise the teams would all be doing this already.
ban the rim then, they too have an aerodynamic effect on the airflow, really what you saying is bullcrap, then alot wouldnt be allowed, as long as it still is a rim it is legal lol, so as long it is simgle piece...
You're wrong. The rim is defined as part of 'the wheel' in the regulations so it is allowed to move.
Have a read:
Definition of wheel
1.5 Wheel :
Flange and
rim.
1.6 Complete wheel :
Wheel and inflated tyre. The complete wheel is considered part of the suspension system.
12.8 Wheel assembly :
12.8.1 The only parts which may be physically attached to the wheel in addition to the tyre are surface treatments for appearance and protection, valves for filling and discharging the tyre, balance weights, drive pegs, tyre pressure and temperature monitoring devices and spacers on the inboard mounting face of identical specification on all wheels for the same axle.
Exclusion zone
12.4.5 No wheel material is permitted in the following exclusion zones :
- A concentric cylinder of diameter 305mm and length 115mm positioned with its inner face lying in the same plane as the inboard face of the front wheel ;
- A concentric cylinder of diameter 305mm and length 25mm positioned with its outer face lying in the same plane as the outboard face of the front wheel ;
- A concentric cylinder of diameter 305mm and length 100mm positioned with its inner face lying in the same plane as the inboard face of the rear wheel ;
- A concentric cylinder of diameter 305mm and length 30mm positioned with its outer face lying in the same plane as the outboard face of the rear wheel.
