Carlo's - but I see all pictures on F1tech embedded in my posts! Maybe it's something wrong on your side?Carlo's wrote:madly, fix the links because they don't work.
Maybe use normal browserCarlo's wrote:maybe send normal links, cheers.
I am also unable to see the pictures.....madly wrote:Maybe use normal browserCarlo's wrote:maybe send normal links, cheers.- in Firefox it's working perfectly, IE don't see it. But WRI2.net use only dynamic links to their images.
I also have a firefox, and it still doesn't work.madly wrote:Maybe use normal browserCarlo's wrote:maybe send normal links, cheers.- in Firefox it's working perfectly, IE don't see it. But WRI2.net use only dynamic links to their images.
Im talking about the faint one, similar to the Mclaren, Williams and Sauber slot. NOT the main slot gap.Carlo's wrote:Yes, most teams have this slot in their rear wings.PNSD wrote:Is it me or is there a slot in that rear wing, to the left of the Bridgestone logo on the endplate?
Blackout wrote:Yes the R30 has new sidepod deflectors and even bargeboards..! (for the first time since 2008)
In this shot the 'ripples' down the side look more like steps.Blackout wrote:Blackout wrote:Yes the R30 has new sidepod deflectors and even bargeboards..! (for the first time since 2008)
Similar view from Jarez tests.plailleur wrote:I have found this on Autosport.com. These new barge boards look a lot like Mercedes'.
n smikle wrote:This rule?madly wrote:@n_smikle - don't you think FIA did full DD check after last upgrade?
Look at the manchild answer:
manchild wrote:Flat floor below bodywork rule stands only for area between wheels (wheels, not axles). For that same reason nose has no flat floor below itself.
It speaks of all parts on the reference and step plane. So that Is what I was following.3.12.5 All parts lying on the reference and step planes, in addition to the transition between the two planes, must produce uniform, solid, hard, continuous, rigid (no degree of freedom in relation to the body/chassis unit), impervious surfaces under all circumstances.
Fully enclosed holes are permitted in the surfaces lying on the reference and step planes provided no part of the car is visible through them when viewed from directly below. This does not apply to any parts of rear view mirrors which are visible, provided each of these areas does not exceed 12000mm² when projected to a horizontal plane above the car, or to any parts of the panels referred to in Article 15.4.7.
You guys post the exact regulation you are talking aboutI need to see it and surprisingly that still would still not excuse renault's diffuser holes because, You can see that some parts of these holes are:
1. Almost touching the rear wheel center line. (not between the tyres as you say)
2. Lying on the reference plane. (other teams hole lie on a vertical plane).
http://img696.imageshack.us/img696/3349/d10aus1806.jpg
Not that I am debasing Manchild's interpretations, but this diffuser is something unprecedented and needs some more looking into.
My only guess is that they are within a certain width or there are similar holes cut out on top of the diffuser roof.
