To achieve any change in valve lift or duration,it would require changes of camshaft or changes to valve mechanism geometry.Skinn3r55 wrote:The compression ratio of the engine is the ratio between the volume available in the cylinder when the piston is at BDC and the volume available in the cylinder when the piston is at TDC. Basically the volume of the whole cylinder divided by the volume of the combustion chamber. I think there would be significant changes required to change that.
What I think you meant is that they can increase the pressure in the combustion chamber by delaying the moment at which the intake valve closes, which leads to an increased enthalpy of the air-fuel mixture (if I remember correctly) and consequently better efficiency.
it would also gain power from less friction on the cam assuming they are running a lower pressure return piston.(not sure what the correct term is on an air system. A nascar v8 losses around 300 hp in the valve train friction. Its not that hard to believe that you couldn't find 15hp from a small change.autogyro wrote:Good idea flyn-frog reducing valve mechanism mass would in ordinary circumstances account for an increase in power from increased engine revs. There is a slight problem with this however, the engines are already limited to 18000 rpm and they all reach the limiters anyway.flynfrog wrote:maybe they were able to take weight out of the valve train and reduce some losses that way.autogyro wrote:Wild attempt: the current valves seal the engine better than they used to. Thus, combustion might be more efficient and the compression ratio is increased. This could also allow running a more powerful mix for longer.
Sorry that does not make sense.
There would only be an increase in compression if the lift, duration and closing of the valves was altered. Correct?
But the problem was stated as a pneumatic leak that resulted in an inability to recharge the gas feed bottle.
(gas valve springs only close the valves, nothing else)
This is a system running out of gas, not a change of any sort to the way the valve train operates.
It would aso have nothing whatsoever to do with improved fuel mixture.
Reducing the amount of gas leakage would in fact 'decrease' any excess gas available for valve and general engine cooling, which would result in a less efficient fuel mix because of higher temperature.
Just thought I would re post this as no one has as yet answered it.
Perhaps there is a draft of what was agreed, that explains everything?
Perhaps but again, why would they be allowed to do anything to valve timing to rectify a pressure loss in a valve spring system?!!Skinn3r55 wrote:I know compression ratio is not the same as pressure. It's just that someone was posting that the change made to the valves would change the compression ratio and i believe that can't be the case.
Also I didn't mean they would want to change valve lift or duration. Just that having the experience of a few races they might have concluded they could obtain better volumetric efficiency by delaying the intake valve a few degrees.
No. Let me be very clear: YOUR POSTS are not worth the effort.autogyro wrote:So technical discusion is not worth the effort.
Says it all.
Calm down dear. You should be countering the post, not the poster [-Xdonskar wrote:No. Let me be very clear: YOUR POSTS are not worth the effort.autogyro wrote:So technical discusion is not worth the effort.
Says it all.
Are you able to grasp that reality?
It was just an ideea. Wanted to see what others would think about it. I guess the FIA would not allow it.autogyro wrote:Perhaps but again, why would they be allowed to do anything to valve timing to rectify a pressure loss in a valve spring system?!!Skinn3r55 wrote:I know compression ratio is not the same as pressure. It's just that someone was posting that the change made to the valves would change the compression ratio and i believe that can't be the case.
Reading what Scarbs wrote it seems that's what they did, and through better valve sealing they gained an estimate 12 HP.autogyro wrote:Wild attempt: the current valves seal the engine better than they used to. Thus, combustion might be more efficient and the compression ratio is increased. This could also allow running a more powerful mix for longer.
The autogyro quote above is incorrect, I did not say that.Skinn3r55 wrote:Reading what Scarbs wrote it seems that's what they did, and through better valve sealing they gained an estimate 12 HP.autogyro wrote:Wild attempt: the current valves seal the engine better than they used to. Thus, combustion might be more efficient and the compression ratio is increased. This could also allow running a more powerful mix for longer.
My bad. I was just reffering to the first partautogyro wrote:Skinn3r55 wrote:autogyro wrote:Wild attempt: the current valves seal the engine better than they used to.
