Renault R30
segedunum
segedunum
Re: Renault R30
autogyro wrote:If there was a way to measure DF there would be.
This would be fairly easy to set up with the FIA.
Of course, it would then allow a direct accurate reference to DF levels that would allow for sensible regulation.
Yep, which is why Eddie Jordan's 'fifty percent reduction in downforce' soapbox suggestion is totall bollocks. You can't measure and you certainly can't compare. Personally, I think this fixation on aerodynamics is nonsense, but I digress.
Miguel
Miguel
Re: Renault R30
You know, assuming constant Cl with speed (and I don't think numbers will change much at the slow F1 speeds), raymondu's numbers surely allow easy comparison... because you are indeed measuring Cl in certain units. Now you only have to find out total units of the RB6, the F10, MP4/25... good luck! I suppose it's STP for all the teams.
I am not amazed by F1 cars in Monaco. I want to see them driving in the A8 highway: Variable radius corners, negative banking, and extreme narrowings that Tilke has never dreamed off. Oh, yes, and "beautiful" weather tops it all.
"Prediction is very difficult, especially about the future." Niels Bohr
RH1300S
RH1300S
Re: Renault R30
Well you can measure downforce - from the point of view of regulating it. All the FIA has to do is stipulate how much is allowed in KG's or whatever. Enforcing it and measuring it dynamically is a whole different problem that has been discussed to death in the past.
All I was saying about points of d/f is that it's a unit the teams refer to.
Perhaps it's as simple as a percentage point - with 100% being as the car starts it's first test? Why tell everyone exactly how many KG's you have at a certain speed.
PNSD
PNSD
Re: Renault R30
On the subject of enforcing it and measuring it.
Should the FIA be allowed to recieved real-time telemetry data from all cars in future? Then things such as suspension loading could be used as a guide to how much downforce? Is that possible?
autogyro
autogyro
53
Re: Renault R30
PNSD wrote:On the subject of enforcing it and measuring it.
Of course it is and it should be simple.
timbo
timbo
113
Re: Renault R30
How would you account for air density/temperature changes?
Different weight transfer?
Also, this would still leave a place for working solely of DF, e.g. shaping DF/speed envelope (like McLaren does with F-duct) to get more DF at lower speed, and using some trickery to reduce DF at high speed.
PNSD
PNSD
Re: Renault R30
Well let's take the long straight at china for example.
In real-time the FIA should see the suspension loading increase as the speed and downforce increase. From that they can take the min and max levels can they not? The only real place they can measure the downforce and compare it against teams is on a straight where weight transfer wouldnt be accountable.
If there were any devices to cut downforce on a straight, that would also be detected through the readings, surley?
Miguel
Miguel
Re: Renault R30
PNSD wrote:Well let's take the long straight at china for example.
And then the car hits a bump, and that sudden peak makes an easy maximum search impractical. Furthermore, you need to know the exact spring rates of the car... including the tires.
RH1300S
RH1300S
Re: Renault R30
Maybe we have veered off topic here - sorry guys I kinda started it with D/F points.
Anyway - briefly it seems to me that the best way to measure downforce is to set a limit. Wind tunnel test the cars in a control environment.
Homologate the bodywork (wings included) and leave it at that for the season. No further changes allowed.
Re: Renault R30
Thanks RH1300S. Interesting
RH1300S wrote: Obviously they were very cagey about some of the parts on view (I should imagine there will also be parts not on view....... :wink: ) - from what I saw there it's obvious there are some very clever things happening with that car.
What do you mean :?: :)
Metal
Metal
Re: Renault R30
RH1300S wrote:They can measure it in sausages for all I care - at the end of the day it only matters to the guys running the car.
Maybe we should say that Renault added 30 sausages of downforce for this weeknd's GP. Then we could all agree to move on........... :roll:
So you're saying that the R30 has gained 30 points of downforce in Monaco??
Exactly what new parts has Renault brought to Monaco? Cuz i havent seen any...
PNSD
PNSD
Re: Renault R30
Thats not what he's saying :p
Paul
Re: Renault R30
RH1300S wrote:They love having Kubica there (I forgot to ask about Petrov.....but I can't see why they wouldn't be pleased with him to IMHO).
I'm sure they do. Oh, the Saturday delight of rebuilding a car after the practice session. [-o< And he pays their wages too.
Metal
Metal
Re: Renault R30
PNSD wrote:Thats not what he's saying :p
So what is he saying?
ARX_RNLT
ARX_RNLT
Re: Renault R30
By the lap chart - this means Renault mached RBR pace in the race? WEB - red, KUB - blue colour.
