You might end up getting stuck behind a slower car after a poor Q3 on primes. It wouldn't matter then how far you could run on the first set of tyres if you had been held up by 1-2 seconds a lap, for 18-20 laps.marcush. wrote:I feel a lot of teams adopt "safe" read mainstream strategies but ignore the fact they are not matching the speed of the front runners anyways.So why should you compromise your elapsed time for your own race?
Or is there anybody out claiming starting on softs on a heavy car would be a quicker option ?I can´t see this.the softs will work best on low fuel and rubbered in track
and open up a much bigger window of usage not just the handful of nursing laps we see .
Of course you could gain even more with a driver who is good at defending track position as you can hold up guys with potentially quicker tyres for a while....but I don´t even think this is a big issue.
but then teams are not filling up their cars as it saves them potentially 5,8 seconds over race distance....discounting they have to run slow to make it to the end...
There where no team orders, Helmet Marko does not speak for the team, he's DM's mate and is only there to pump up Seb's tires and apparently cause trouble for Mark (see Flav Manager BS rumours he started last year)!zenithbeach wrote:indeed! and i agree with him though i dont see the point in arguing about whose fault it was cause it clearly doesnt change the outcome. i was merely pointing out the initial statements and the obvious team order that was failed to be handed down to webber by his race engineer.djos wrote: it doesn't get any clearer than that!
Had they come a cm closer they would have crashed, as they did come together at one point, but not quite enough to cause trouble. Purely luck though. That would have been insanely hilarious if they took each other out. Not because they're McLaren, but for the sake of entertainment and irony.Ray wrote:... Also it was awesome to see Lewis and Jenson dice like that for a bit and not give an inch but not crash each other too, consummate professionals...
They did appear to graze wheels at one point so they where very lucky - Great dice tho!mx_tifosi wrote:Had they come a cm closer they would have crashed, as they did come together at one point, but not quite enough to cause trouble. Purely luck though. That would have been insanely hilarious if they took each other out. Not because they're McLaren, but for the sake of entertainment and irony.Ray wrote:... Also it was awesome to see Lewis and Jenson dice like that for a bit and not give an inch but not crash each other too, consummate professionals...
One thing that trumps starting on hards for the slow teams in top 10 is the safety car. It's best to be on softs if there is an early saftey car. You dont want to be on hards when a SC comes out on lap 5 and then have to come in to the pits only to run softs for 50+ laps.marcush. wrote:I feel a lot of teams adopt "safe" read mainstream strategies but ignore the fact they are not matching the speed of the front runners anyways.So why should you compromise your elapsed time for your own race?
Frankly, I don't care what was said by the teams and drivers because that has proved not to be reliable. Look at the lap times of Webber, Vettel and Hamilton and the gaps between them and then look at the lap times of Vettel and the gap to Hamilton in the two laps prior.dannyteasdale wrote:I dont want to sound abrupt but Its not incorrect.
The opinion is based on what was actually said by the teams, drivers etc.
If you have stats then I will do no other than agree - Although I doubt you do have.
Given that Vettel was doing similar lap times to both Webber and Hamilton prior then that means they did something to Vettel, not to Webber.(BTW If Webber and Hamilton were in fuel conserve mode - and Vettel wasnt - That would obviously make him faster - So yes some of the above statement is correct - But not in the way I think you mean.)
It's a FACT - in capitals no less. How can one argue with that?Poleman wrote:You have every right not to believe it but the history of the 7 races so far shows that McLaren are chopping some tenths in EVERY race.Thats a FACT.Even 0.1-0.2 doesnt really matter its still an improvement.
Exactly. The whole paradox is that Mark ended up better off in relation to his primary threat. Probably no reason to be too disappointed really, other than losing ground to Mclaren.ISLAMATRON wrote:after all is said and done Vettel got just what he deserved for his stupid move, a DNF... Now he is 15 points behind Webbo instead of the 7 had he not rammed him.
Points are so stupid
