Meant to post this last night, but the server was down...
WhiteBlue wrote:I still don't understand what makes the track one of the greats. I think it is worthwhile to find out because it may be the key to what Americans love in road racing.
The key to this track is the subtle technicalities that, as X mentioned previously, separate the men from the boys. There are several 50-100 mph corners that are at the end of nearly (or even exceeding) 200 mph straights and they aren't flat, smooth braking zones. And you need to get a good entry to set up the exit because corner exit is also critical there because the straights are so long. This is what I believe makes for a good F1 track. The cars have so much power and speed that you need a long straight to make a run on a guy, period.
We've seen some of these long straights leading to hard braking corners on the Tilke tracks, and they are consistently the hot overtaking locations. For example, see turns 1/12 at
Turkey, turn 8 at
Abu Dhabi, turn 1 in
Malaysia, turn 1 in
China, etc. The problem with those turns in Malaysia, China, and Abu Dhabi is they are immediately followed by a turn in the opposite direction with very little distance from corner exit to follow on corner entry. So, if you don't pass cleanly by the corner exit then you're hosed because you've gone off the racing line to get position into the previous corner and you're tires are dirty and your opponent has both cleaner tires and a better line in to the follow on corner.
You don't have that at Elkhart. The straights are long enough that you have a passing opportunity going into turn 1, or if you get turn 1 right you can set up for turn 3. You've then got a tricky braking zone going into turn 5 after a high speed straight, which can set up passing. Or, again, at the very least if you get through cleanly at 5 you set yourself up for a possible run through turns 7/8. Then if you get the flat out carousel right, or if you have a car like the Red Bulls in turn 8 at Turkey that can run flat out when others can't, then you set yourself up for a pass in 12. And none of these turns have a follow on opposite direction turn.
So you've got a track that offers high-speed, flat-throttle corners and very high speeds on the straights coupled with hard braking zones. Not to mention you have elevation changes, and it's arguably in one of the most beautiful areas of this country. Also, the weather in Wisconsin would be almost perfect this time of year (Canada was last weekend, good for logistics...
![Wink :wink:](./images/smilies/icon_e_wink.gif)
There are also some intangibles that make it a favorite track over here. It does have a lot of history with other series. I also personally like it because it isn't "sterile" like a lot of the newer tracks, at least in my opinion. No, it doesn't have a perfect looking surface. It doesn't have a hotel spanning the track and covered in color-changing LED lights. Are the garages enormous in capacity? No, at least not compared to the places the teams are accustomed to currently. But do they really
need that to get a car on the track? Like I said before, 43 NASCAR teams are going to get along just fine. I'm sure 24 F1 teams/cars could make it work. Since when is extravagant luxury an absolute requirement for an F1 race to take place anyway? It may have become the status quo, but it doesn't have to be. These guys can suck it up and "rough it" for a weekend if they have to. They'll get over it, trust me.
Now does that mean the track is perfect in it's current state? No, it does need some infrastructure upgrades, such as larger grandstands. However, the Bernie fee is clearly the largest obstacle for any new race. If you have a 30 Million USD fee, and a large seating venue that can hold 200,000 fans, then the average ticket price is 150 USD. So to just get a family of four through the gate, you have to cough up $600 (on average). Frankly, that's pretty steep. It's just not a realistic, sustainable number without some government assistance or significant sponsorship. At the end of the day, Bernie is the road block. If he would ask a more modest fee, there are several great tracks stateside that could host an F1 race. They just can't afford it on their own.
Going back to the discussion of the track above, this video does a good job of amplifying some my points about the technicalities of the track...
[youtube]
http://www.youtube.com/watch?v=duNKaCRm ... re=related[/youtube]
