marcush. wrote:of course you can.The wing is not alowed to move relative to the car .End of story .If you mount your camera to the wing stay and you see moving parts of the car relative to this .some eplanation is necessary .
I think your seeing things you want to see. Look at the red line, the tray barely moves. The took at the rear wheel by the 7-11 barge board. The whole car is up and down not splitter.
If you think that is the wing moving marcush then look carefully at the splitter shadow...its the car going lower, not the wing moving in relation to the car.
Its a combination on bumps, d/f and shadows. Noting in that picture whatsoever imo.
