Mine too, 747.747heavy wrote:But the delay in force build up in quadrant 3 is "typical" for post caviation, because it takes time to "collapse" the "gas bubbles" and make the oil an incompressable fluid again. - IMHO
a bit like shown with the red piston at the top leftDaveW wrote:appears to be caused by a delay in opening of the damper shims, which appears, in turn, to be caused by capillary forces "binding" the sealing shim to its piston.
Interesting paper. Incidentally, I'm told that the "chuckle" phenomenon isn't (so) observable when the damper is tested by a dyno. That raises the possibility that some damper characteristics are impedance-sensitive. Put crudely, a damper is forced to prescribe a specified displacement time history when it is mounted in a dyno, regardless of the force time history. When installed in a car, however, the damper displacement time history is not prescribed; if it wants to pause for any reason, it can do so....747heavy wrote:an SAE paper to complement DaveW´s comments, in regards to the damper "chuckle".
Hi Wilo,WilO wrote: 747, I was wondering if I might ask you where you found that illustration of the damper cycle/potato plot.
At work here we do keep that in mind when we design our pistons, which most of them are machined at the moment during prototyping. The effect is definitely something we monitor, and tries to minimize if possible747heavy wrote:Thanks for your insights, very interesting and much appriciated.
Some manufacturers of racing dampers/piston machined from aluminium,
reduce the contact area of the seal shim with the piston face, for the reasons you mentioned - I think.
I am tempted to suggest that you might like to repeat the experiment after replacing the hose by a machined adapter, but that would assume that you are comfortable rebuilding & recharging the damper. A fairly easy (though not conclusive) alternative would be to carry out runs at temperatures of, say 20, 40 & 60 deg C with settings 3/3.Belatti wrote:There you can see how hysteresis very low when the damper is not under heavy load. Then it increases when you turn the faucet.
