Red Bull RB6
univex
univex
Re: Red Bull RB6
Formula1.com:
In Japan the two Red Bull drivers ran two different front wings, two different diffusers and the same new rear wing the team introduced at the last round in Singapore. This featured an F-duct directed on to the main plane (red arrow), in a similar way to the one featured on the Renault. A new feature was the beam wing, with a delta shape in the middle.
http://www.formula1.com/news/technical/ ... 9/800.html
Hard to tell but possible difference in the end plate openings.
zgred
Re: Red Bull RB6
Holm86
247
Re: Red Bull RB6
Cant see any diffirence in those front wings???
But was Vettel favoured then?? did he have the best front wing and diffuser??
Re: Red Bull RB6
Dont know if some one mentionned it but
Before (thx to F1-technical for this image)
After
forty-two
Re: Red Bull RB6
Blackout wrote:Dont know if some one mentionned it but
After
Wow, good spot. Only problem is that the "After" image doesn't show anything other than the wheel, so there's no way of telling if the camera was horizontal or not.
I'm not saying that I doubt the validity of this comparison, merely that it's impossible to be sure from that image alone.
The answer to the ultimate question, of life, the Universe and ... Everything?
Holm86
247
Re: Red Bull RB6
It is true. According to formula1.com Reb Bull changed their brakecalipers to a more usual upright position. Because of brakeproblems they have had throughout the season.
Lurk
Re: Red Bull RB6
univex wrote: Hard to tell but possible difference in the end plate openings.
I think endplates are the same...
Maybe they tested 2 wings friday ?
edit: end of FP2.
ImageThey are exactly the same.
And they used the same wing during FP1.
http://www.motorsport.com/photos/f1/201 ... p-0261.jpg
http://www.motorsport.com/photos/f1/201 ... p-0252.jpg
Midnight-34
Midnight-34
Re: Red Bull RB6
They used a diferent brake configuration at suzuka,
the position of the brake pads is now vertical like other cars, the made this change to promote reliability
Giblet
Giblet
Re: Red Bull RB6
Midnight-34 wrote:They used a diferent brake configuration at suzuka,
Very interesting, good find. I had predicted that the low brakes were the reason for the semi-failure Seb had when he thought he lost engine power, so they must find them somewhat problematic.
aral
aral
26
Re: Red Bull RB6
Yes, with the previously used horizontal siting of the calipers, there was more likliehood of grit lodging , as appears to have happened on vetels car a couple of races ago. F1 fanatic, had details of this yesterday.
747heavy
Re: Red Bull RB6
did both cars use the new caliper layout?
maybe I see it wrong, but it still looks pretty horizontal to me??
or are we talking about the front calibers?
that looks more like it - no?
- Colin Chapman
mep
29
Re: Red Bull RB6
How do you think the position of the calibers affects reliability?
Appart from better cooling maybe.
bar555
bar555
Re: Red Bull RB6
Red Bull Pull Rod suspension: What is looks like – How it benefits aerodynamics
http://scarbsf1.wordpress.com/2010/10/1 ... odynamics/
credit : C. Scarborough
Future is like walking into past......
Blog : http://formula1techandart.wordpress.com/
Twitter :http://twitter.com/bar555onF1
imightbewrong
imightbewrong
Re: Red Bull RB6
bar555 wrote:Red Bull Pull Rod suspension: What is looks like – How it benefits aerodynamics
Bravo Scarbs! Excellent as usual, you are a hero here at F1T!
aral
aral
26
Re: Red Bull RB6
mep wrote:How do you think the position of the calibers affects reliability?
They were placed horizontally, at the bottom of the disc, so as to lower c of g. But due to the curvature, grit was able to lie in the arc and get between the pad and disc. This happened Vettel two or three races ago, leading him to believe that there was a problem, and allowing Webber to pass.
