flynfrog wrote:the area where you CO2 chamber meets your body could use some work maybe simplifying the co2 chamber a little. also remember you want a sharp break away on the trailing edge of things. The car is looking much better than when you started. You really need a way to test these either on the computer or in real life. Otherwise we are just taking shots in the dark.
Lightspeedrt brings up a good point look to other fast cars for inspiration. But you need to understand why they did something.
Im downloading a pirated Phoenics V2009 CFD right now,hope that it will work fine.
I'll try cut this thing out and try to compare it to my previous designs.
Do you have any suggestion for CFD software that i can use?
Maybe i'll found it somewhere if i google it.
And about the WT,we're building it.
