F1 In Schools help : Pudin's project
pudin
pudin
I need a little help for my little car here.
It just a simple picture of the car because the car's files is in my school's pc.
Ok now for the car(the naked one),as u can see below,my front wing shape like a d shape or "the scorpion" shape given by our advisor.Compare it to the Basilisk's car in the international level,which is better?Their front wing is an elliptical shape or a tear drop shape for the front and the rear wing.Im curious which one is better for my car?I will update the car looks for the bottom view and for other angles.And btw our country which is Malaysia have different rules and regs compare to other country.
In malaysia almost anything is legal.My team will compete for 2010/2011 competition
Reason: edited title to identify poster out of many similar topics
I love my mom
pudin
pudin
Re: F1 In Schools help : Pudin's project
Here a better view of my car
I love my mom
flynfrog
Have you read the other thread?
Do you understand the reasoning behind his car shape?
pudin
pudin
But the other thread doesnt say about those front wings,
I only know that their co2 chamber is blunt for supersonic air flow or something like that.
Their new car very different then their old one.
I love my mom
pudin
pudin
You said that building a car for this type,the most important thing is the weight.
If the lighter the car,the better.
Am im doing a good job lowering the car's weight without affecting the car's aero?
Im not good at the aero stuff.
I hope you can guide me,and yes i've read the basizeland forum and did take some knowledge such as the smaller the rear wing the better and other important things
I love my mom
flynfrog
If your rules allow no min weight that will be your biggest gain.
I believe Bazilands car had to weigh 55g
I am not sure what rules you are working for but if you can shape your side pods to cover more of the wheels it would help.
also blunting the front of your car as apposed to the sharp points will aid in keeping flow attached.
have a read of this site. Keep in mind you do not want your car to fly or create down force. http://www.rcaeronautics4dodos.filipino ... es_fly.htm
flynfrog
have a look at the winning cars notice how they are simple shapes instead of lots of cuts every where?
http://www.science-of-speed.com/showroom.asp?id=285
pudin
pudin
I've tried to cover the wheels as much as possible.
And the rule has changed,so i have to make a new car based on the basizeland car.
Im kinda rushing so it looks messy a bit.
Is this what u said flyn?
It's rear wing is not visible because it just a small attachable neutral rear wing which is the best for this race
I love my mom
flynfrog
looks like a good start remember no points on the leading edges
think more Le mans car with open wheels
pudin
pudin
The leading edges will be taken care when we manufactured it.
Here a complete view of the car.
Is it okay?
Or there's something wrong about it.
And does anybody knows how to paint,add stickers,vinyl to the car by using any softwares?
I love my mom
flynfrog
There is nothing wrong with it per se but Its far from optimized. It looks to be a good start. Remember your airfoil can be in two dimensions. also you may find that you have created a nozzle with the under body of your car. this will add drag.
http://en.wikipedia.org/wiki/Venturi_effect
real F1 cars use a venturi to create down force. Your car will see no benefit from down force and your nozzle is in the wrong direction.
pudin
pudin
Then u mean(venturi) that i must change my centre body or my front wing with other shape?
And i cant do anything about the nozzle position because it is too hard to make a shape like basilisk's car nozzle.
It is producing unnecessary drag but i cant do anything about it.
Do you have any idea?
I love my mom
flynfrog
look at this pictureImage
see how you are squeezing the air together only to let it expand at the back of the car? that all takes energy that should be pushing your car down the track
pudin
pudin
Is this okay?
Or should i close the gaps around the co2 chamber as well?
I love my mom
flynfrog
I would try to blend it all together a little better. Trying using a loft or a sweep
think more like the Steve Rooney car
http://norcald3.8.forumer.com/a/brookla ... 462-0.html
Also look at the lemans car I poster earlier. notice they don't have a point on there windshield bubble its a nice blended curve. Image
Your car is still a little square and chunky
