Williams FW33
WhiteBlue
92
Re: Williams FW33
roadie wrote:So, more KERS issues keeping the car in the garage. Certainly disappointing, as I was hoping they'd sorted KERS in the time between now and the last test. I'm certainly looking forward to seeing more photos. Does anyone think in the photo above they have opened up the rear of the car for cooling?
According to Sam Michael Williams have problems with the software driving the inverter. That is bad news in my view. Williams have decided to buy all the KERS components from the source and that means the operating software for their IGPTs will be unproven. It could take them some races to fix all the problems they have. Williams shares went down below €23 today.
ESPImperium
ESPImperium
64
Re: Williams FW33
Seemingly Williams are contemplating not running KERS for the start of the season due to relyability concerns:
http://translate.google.com/translate?h ... -SearchBox
May be a good stap for them, as the Williams KERS is oviously fragile, but both the Renault and Ferarri systems arent exactly being great for relyability for Sauber and Lotus Renault GP. Even Mercedes have had problems with the "great" Mercedes system, but theirs is mostly down to cooling.
nacho
nacho
Re: Williams FW33
With so many problems in other teams I think it might be very beneficial to have a reliable car in the first races, there will be lots of points to collect even with a slower car.
zgred
Re: Williams FW33
nacho
nacho
Re: Williams FW33
Autosport are reporting that Barrichello had a very small drop-off in his race stints, only a second in 10-12 laps. Sounds extremely good for Williams.
axle
axle
Re: Williams FW33
If there is doubt in the systems operation it shouldn't be used. Instead I would focus on optimising the car to the tyres and placing ballast in a better location to further improve the car. Oz could well be won by a tortoise rather than a hare!!
However, if they are confident in running KERS in 2 weeks it should be assumed that the data they have collected has been analysed, fixes produced and they will have a hybrid tortoise :)
I predict Q3 for at least Rubens in Oz.
- Axle
WhiteBlue
92
Re: Williams FW33
Autosport live reports that Williams will run KERS at the Australian GP. It looks like they found the fault in the inverter.
sac
Re: Williams FW33
Scarbs has got hold of some FW33 gearbox pics:
http://scarbsf1.wordpress.com/2011/03/2 ... in-detail/
sac
Re: Williams FW33
Hangaku
Re: Williams FW33
Goddamn. How can there possibly be a gearbox in that handbag?
Yer.
Francesc
Francesc
50
Re: Williams FW33
halllo_fireball
halllo_fireball
Re: Williams FW33
Hangaku wrote:Goddamn. How can there possibly be a gearbox in that handbag?
Gearboxes are incredibly small indeed, as there is no torque going into them :mrgreen: You also have to consider the limited lifetime...
jenkF1
Re: Williams FW33
What are the disadvatages to running such a high angle of a driveshaft/halfshaft? I beleive its 14 degrees on the FW33. I am thinking efficiency of drivetrain and reliability?
i70q7m7ghw
i70q7m7ghw
49
Re: Williams FW33
jenkF1 wrote:What are the disadvatages to running such a high angle of a driveshaft/halfshaft? I beleive its 14 degrees on the FW33. I am thinking efficiency of drivetrain and reliability?
Good question, It's been asked quite alot during winter testing, there is an interview with Sam Micheal somewhere. Basically, Williams did ALOT of dyno testing with Cosworth to make sure it was going to work, they seem quite confident.
halllo_fireball
halllo_fireball
Re: Williams FW33
Didn't they use the highly sophisticated dyno at the Toyota facilities?!
