I think those silver pipes closest to the camera are leading to the radiators but if you look further in the background you can see the top of exhaust feeding across the floor and down behind/beside the rear tyre - is that what we're looking at?richard_leeds wrote:I don't think that the exhaust pipe, I think its the coolant pipe leading to the radiators.
Yes, it was a superb 1-2 this weekend at Oz.Robbobnob wrote:seems to be working so well for them *sarcasm off*
The silver pipe bending down is for the radiator. The other two bending back with nipples on them are the exhaust pipes.bonjon1979 wrote:I think those silver pipes closest to the camera are leading to the radiators but if you look further in the background you can see the top of exhaust feeding across the floor and down behind/beside the rear tyre - is that what we're looking at?richard_leeds wrote:I don't think that the exhaust pipe, I think its the coolant pipe leading to the radiators.
Also there looks to be a support attached to the exhaust and the floor I guess to try to control vibrations?
The nipples being the O2 sensors mounting points IMO.dren wrote: The silver pipe bending down is for the radiator. The other two bending back with nipples on them are the exhaust pipes.
I agree, it looks like it flattens out towards the back like the Red Bull and Ferrari solution.Dragonfly wrote:The nipples being the O2 sensors mounting points IMO.dren wrote: The silver pipe bending down is for the radiator. The other two bending back with nipples on them are the exhaust pipes.
It seems to me that the exhaust pipe inner profile goes from oval to wider but flattened shape at the edge of the floor in front of the rear wheel. But not quite sure.
bonjon1979 wrote:If you look between the mechanics legs you can see what looks like the end of the exhaust pointing down under the floor.beelsebob wrote:With none of the pipework there it's hard to tell, but there's a bump at the back of the side pod that wasn't there before, and a turning vein similar to red bull's behind it – could this be the new exhaust?
ringo wrote:beelsebob wrote:With none of the pipework there it's hard to tell, but there's a bump at the back of the side pod that wasn't there before, and a turning vein similar to red bull's behind it – could this be the new exhaust?
seems that bump was always there.
dren wrote:The silver pipe bending down is for the radiator. The other two bending back with nipples on them are the exhaust pipes.bonjon1979 wrote:I think those silver pipes closest to the camera are leading to the radiators but if you look further in the background you can see the top of exhaust feeding across the floor and down behind/beside the rear tyre - is that what we're looking at?richard_leeds wrote:I don't think that the exhaust pipe, I think its the coolant pipe leading to the radiators.
I notice a lighter grey zone on the flor in this picture. What do you members think it comes form?Dragonfly wrote:Image filtered, more details can be seen. Please comment, I am not so much into it to venture a comment.
Uploaded with ImageShack.us
Is that temperature sensitive paint striped on the top of the diffusor as MGP were using during the last test?senftl wrote:Exhaust now fitted and blowing all over the diffusor (at least not slots to be seen here)
