Looks like Mclaren are using a Ferrari type exhaust
That is almost certainly the reason, as mentioned by Jonathan Neale on the Flying Lap Ep 7.kalinka wrote:EDIT : Maybe those filters are there because of the espected high degradation of tyres...against marbles falling in to the duct ?
I think that's backwards. The two pipes with colored bands and nipples are the radiator inlet and outlet, though it seems unusual to have them on the same corner.Dragonfly wrote:The nipples being the O2 sensors mounting points IMO.dren wrote: The silver pipe bending down is for the radiator. The other two bending back with nipples on them are the exhaust pipes.
It seems to me that the exhaust pipe inner profile goes from oval to wider but flattened shape at the edge of the floor in front of the rear wheel. But not quite sure.
judging by the vertical panel attached to the ground, the side pods will be tucked in.WilliamsF1 wrote:Looks like Mclaren are using a Ferrari type exhaust
Didn't know that, as I just started to look closer into the cars this yearmarcush. wrote:redbull had that radiator double pass layout already last year .They seemed to divide the core even more splitting up the core in 5(?) sections .speeding up the flow in the core is giving you a lot more heat transfer.
