It's legal to the letter of the rules. It contravenes the spirit, but not the letter. That's the critical difference. F-duct? Double diffusers? Bad time to start getting selective memorybot6 wrote:Definitely what puts them ahead. McLaren are the only other team doing this and look how much better they suddenly are...Joie de vivre wrote:good job from RB, just stunning how the front wing is flexing like crazy
i wonder how others still havent figured it out or maybe there are just not trying to understand the concept of it
I think the others know what is going on, how could they not? But that bending wing thing is blatantly braking the no movable aero regulations, therefore illegal. So I'm guessing the other teams are more tentative in braking the rules.
Going around the FIA test does not make this thing legal. So either the FIA needs to change the rule so that this is made legal, or they need to change the test so no one can use it.
At the moment, this is just going to kill the racing...
Actually no it's not legal to the letter of the rules. It passes the test designed to enforce the rules. The letter of the rules state no flexability (within a margin). From TV footage and pictures it's clear the Red Bull wing breaks this rule, but footage and images are not enough to prove it. The FIA need to think of a better way to enforce the rule, I suspect they will introduce more standardised front wing components, in later seasons ofcourse.raymondu999 wrote:It's legal to the letter of the rules. It contravenes the spirit, but not the letter. That's the critical difference. F-duct? Double diffusers? Bad time to start getting selective memorybot6 wrote:Definitely what puts them ahead. McLaren are the only other team doing this and look how much better they suddenly are...Joie de vivre wrote:good job from RB, just stunning how the front wing is flexing like crazy
Err no it's not. It's utterly illegal according to the letter of the rules, but passes the FIAs designated test that is supposed to catch people contravening the rules. The rules categorically state that first and foremost flexible aerodynamic parts are not allowed and that this rule supersedes the subsequent rules related to the test, allowing the FIA to upgrade or change their test at any time without the teams consent.raymondu999 wrote:It's legal to the letter of the rules. It contravenes the spirit, but not the letter. That's the critical difference. F-duct? Double diffusers? Bad time to start getting selective memory
Tech Regulations 2011, article 3.15 wrote: Aerodynamic influence :
With the exception of the driver adjustable bodywork described in Article 3.18 (in addition to minimal parts solely associated with its actuation) and the ducts described in Article 11.4, any specific part of the car influencing its aerodynamic performance :
- must comply with the rules relating to bodywork ;
- must be rigidly secured to the entirely sprung part of the car (rigidly secured means not having any degree of freedom) ;
- must remain immobile in relation to the sprung part of the car.
Any device or construction that is designed to bridge the gap between the sprung part of the car and the ground is prohibited under all circumstances.
No part having an aerodynamic influence and no part of the bodywork, with the exception of the skid block in 3.13 above, may under any circumstances be located below the reference plane.
So it is illegal since the wing bends under the reference plane and is designed to be as close as possible to the ground.Tech regulations 2011, article 3.17.8 wrote: In order to ensure that the requirements of Article 3.15 are respected, the FIA reserves the right to introduce further load/deflection tests on any part of the bodywork which appears to be (or is suspected of), moving whilst the car is in motion.
can you get a working link to the first pic. im interested!ParanoiD wrote:Check how low close to the Tarmac the front wing is running on
That was true until last year I believe, but it's not in the regs this year as the FIA probably decided the "no flexing at any time" rule was impossible to enforce. So they replaced it with a long list of tests and restrictions.myurr wrote:
So if anything this is just incompetence by the FIA in enforcing their own rules.
Edit: Sorry just say Diesel say pretty much the same thing.
Can you quote a source for this rule change please. I was not aware if any changes to the rules regarding flexible bodywork.bot6 wrote:That was true until last year I believe, but it's not in the regs this year as the FIA probably decided the "no flexing at any time" rule was impossible to enforce. So they replaced it with a long list of tests and restrictions.myurr wrote:
The spirit of the rules is indeed what you describe, but that spirit is not stated in the regs anymore (which I do find stupid, but I'm not an FIA lawyer...)
EDIT: Guys, I just want to make it clear that this is not an anti Red Bull crusade. I have nothing against Red Bull as a team. I just want everybody to race under the same rules so that we can have some close and exciting racing.
murtoidf1 wrote:can you get a working link to the first pic. im interested!
