Williams FW33
Formula None
Formula None
Re: Williams FW33
Richard
Richard
Re: Williams FW33
Great livery, especially the numbers. From f1fanatic tweet.
230
Re: Williams FW33
This car is quick. It could be fighting with the merc and mclaren.
jenkF1
Re: Williams FW33
ringo wrote:This car is quick. It could be fighting with the merc and mclaren.
As much as I love it and its been quick, its still doesn't look in the Merc or Mclarens league at the moment.
dren
226
Re: Williams FW33
Hard to tell where the Renault is at the moment, but so far I'd put the Williams as best of the rest. We'll see in a few hours!
Honda!
zgred
Re: Williams FW33
sac wrote:Image
Formula None
Formula None
Re: Williams FW33
Thanks again, zgred. Hopefully the RB7 box breaks cover soon.
You can pretty clearly see the bosses for mounting the torsion bars/bellcranks (the conical shape at the base, below the portholes).
Also, is this upside-down single keel suspension setup pretty unique? I haven't seen that at the rear before.
Francesc
Francesc
49
Re: Williams FW33
Why you would say that? Because of the fast laps of each driver? You will be surprised.
Tim.Wright
330
Re: Williams FW33
Formula None wrote:Also, is this upside-down single keel suspension setup pretty unique? I haven't seen that at the rear before.
It pretty interesting geometry. Even though thr upper arms are longer (upside down single keel) it looks like they have still managed to get camber gain into the suspension by sloping the lower arm downward and keeping the upper one parallel to the ground.
This will unfortunately give you a higher roll centre but the losses due to this are probably (hopefully!) mitigated by the better aero performance. Possibly...
Tim
Formula None
Formula None
Re: Williams FW33
Nice perspective on the tiny gearbox:
n_anirudh
n_anirudh
Re: Williams FW33
AT&T Williams
CHT
CHT
-6
Re: Williams FW33
read that Williams is going to introduce the RBR style exhaust system for Shanghai GP. Will that "upgrade" worth 0.5sec?
raymondu999
Re: Williams FW33
It depends how well it works, on their implementation, and how much that actually affects their aero. RBR's rear end is very different from Williams' nonexistent rear end configuration. Also I don't think we can actually use tenths to quantify upgrades. Most teams do, but it's rubbish IMO. I mean, something that gains you 0.5s at Monza probably wouldn't gain you 0.5s in Suzuka. Considering different corners, different straight lengths, different lap lenghs etc
失败者找理由,成功者找方法
Formula None
Formula None
Re: Williams FW33
Looks like they were testing different radiator exit sizes (in the last two images).
Edit: clarified.
raymondu999
Re: Williams FW33
Isn't it the same in the first 2 pictures?
失败者找理由,成功者找方法
