Technical Regulations for 2009-2015
andrew
andrew
Location: Aberdeen, Scotland - WhiteBlue Country (not the region)
Re: Technical Regulations for 2009-2015
^ As far as I know. yes and yes.
It is only the use of the DRS that is restricted.
Antti-san
Antti-san
Ah, OK. Thanks for the quick reply! :)
Dragonfly
Dragonfly
As long as the predetermined amount of energy has not been spent already, yes and yes.
In fact I think we saw this in Australia, not sure about the drivers ATM, but the TV director displayed the on-screen information for both. One (the chaser) had the energy almost spent and DRS active, the defender used it to counter the attack.
Spa 2012
raymondu999
Basically KERS is only limited technically. In how much energy can be used in a lap, and how much energy can be output at maximum. THe usage on track of it is unrestricted. You can use it when you're braking too if you want. But that wouldn't do much good :P
失败者找理由,成功者找方法
Javert
In a near future, FIA should force a conventional exhaust solution, away from the bodywork, in 2009 style
Teams are spending imho too much money in heat-resisting materials
FEE, Mercedes-style, RB & McL & Ferrari ... too many exhaust solutions
Maybe in '12 or '13 ?
bot6
bot6
It's going to become harder to use the exhausts to feed the diffuser anyways with the return of the turbo engines...
Caito
Caito
Javert wrote:In a near future, FIA should force a conventional exhaust solution, away from the bodywork, in 2009 style
Sorry, but, could you define too much money? How do you know it's too much money?
Can you quote values for the heat resisting materials?
Come back 747, we miss you!!
i70q7m7ghw
i70q7m7ghw
49
And that would be yet another wrong solution for the 'spending problem'. If teams have got money, they will spend it, budget caps need to be put in place, let them spend it how they like. If they blow all their money on heat resistant material, and forget to build the rest of the car, so be it!
Banning innovation in the name of cost saving is stupid. If you wan't to solve a problem, attack it directly.
Caito
Caito
Trying to regulate the amount of money they spend is like trying to regulate their ECUs and read 1000's of lines of code, lookng for that option 13.
Teams want and will spend all the money they can to win. For example, the engine freeze(which I dislike) reduced a lot the "engine development departments" so that worked as a cost reduction.
Does anyone know what changes they plan to make for next year? More Kers power? Ban on off-throttle engine maps? No longer restricted weight distribution? Any aerodynamic restrictions?
Dragonfly
Dragonfly
Don't know, but today it seems to me WSMC placed another nail in the coffin of F1.
Spa 2012
dren
227
Caito wrote:Teams want and will spend all the money they can to win. For example, the engine freeze(which I dislike) reduced a lot the "engine development departments" so that worked as a cost reduction.
True to an extent. That cost reduction was most certainly used in other areas. The engine departments were reorganized to suit the regulations. The money was redistributed to better suit the teams. I wouldn't believe any team saw actual savings from the engine freeze. It did allow smaller teams to purchase engines at a set rate, which I am against.
Honda!
dren
227
It looks like the 1.6l V6 turbo engines are a go for 2014. All the teams agreed on it. So two more years with the V8s...that is until they decide to change the regulations again :)
On a side note, I am fully against mid-season regulation changes like they are doing with the EBDs.
Honda!
andrew
andrew
dren wrote:On a side note, I am fully against mid-season regulation changes like they are doing with the EBDs.
Me too. I think these are only acceptable of safety grounds. Doing it in an attempt to reduce a certain teams advantage and possibly increase the entertainment value is not the right thing to do.
dren
227
Agree 100%. Only ban or change the regulations for safety reasons only.
Honda!
