McLaren MP4-26 Mercedes
senftl
senftl
Re: McLaren MP4-26 Mercedes
At least the FW was close to the ground under braking:
kalinka
kalinka
sriraj1031 wrote:
kalinka wrote:That Force India solution looks ugly. Even McLaren's first attempt at Asutralia was better.
Can you please elaborate whats so ugly about it and please post comparison pics between the two to call it ugly
Maybe it's a bit harsh word to call it ugly. Comparison pics were exactly above my post, so I don't want to re-post them. When I called it ugly I meant for those exposed-to-air mounting points alongside the long exhaust pipe. There are two visible screws that secures the exhaust to the floor. Also it seems like the pipe is running a bit over the floor, and not integrated into it, while at McL the mounting points are hidden/at least not in the way of the air. Unless it's their (Force India) intention to do that way, I would call it at least an ineffective solution, but for me it's a bit ugly too. Sorry, no offense.
sink
sink
senftl wrote:At least the FW was close to the ground under braking:
[url =http://imageshack.us/photo/my-images/60 ... 20m29.png/][img ]http://img600.imageshack.us/img600/4444 ... h20m29.png[/img][/url]
Im guessing low tire pressure.
HampusA
Fantastic image really. Shows part of the airflow very nicely.
And yes, i remember someone saying that they fiddled with his tire pressures to maybe try and heat them up quicker.
The truth will come out...
Richard
Richard
They would have put more air into them to compensate for the fact that they were cold and never going to get to full temp.
HampusA
But wouldn´t he have even less grip if they would have increased the pressure?
sink
sink
My guess, more air but due to the lower temps, no higher pressures. I can't imagine them doing this though, that would mean they were doing another run with sub-optimal tire temps -> low grip. I'm guessing they were hoping for the tire temps to get in the right range through the outlap.
Additionally, the track was cold and the brakes were cold. This was for all cars, notice the times were all 1 second slower after the restart.
hardingfv32
hardingfv32
35
"But wouldn´t he have even less grip if they would have increased the pressure?"
For the correct tire spring rate and optimum contact patch shape you need a specific pressure. From experience the teams know when to hit this ideal pressure. I could imagine it to be somewhere during the qualifying lap, start low and end high. Since the rims and tires are pre heated we might not be talking about that much pressure gain.
Brian
HampusA
I see, thanks.
Formula None
Formula None
adrianjordan
How long has Verizon (45% owned by Vodafone) been on the rear wing?
Favourite team: McLaren
ref: Formula None's picture.
Are there slots in the upper surface of the leading edge of the sidepod cut out? They don't appear to be shadows/reflections.
boyracer94
boyracer94
Yes, I believe they were added early in the season/late testing.
I think Verizon has only been on the RW for Monaco so far
JackHammer
adrianjordan wrote:How long has Verizon (45% owned by Vodafone) been on the rear wing?
I was wondering that too, had a look at some old pics, new for Monaco
Catalunya pic of RW
